Hp 5069-6732 card reader - Televison & Video
Hp 5069-6732 card reader manufactured by Northstar
This card reader came out of an Hp pavilion a705w pc case. I am trying to find a cable schematic for this card so i can determine if this cards cable is compatable for connection to my nine pin connector on my motherboard. My pc is a Model: Gateway 510S with an
Intel (Midway) Pentium 4 Motherboard
6ya staff
SOURCE:
Anonymous
  • 1027 Answers
SOURCE: Promise SATA300 TX2 Plus PCI controller card compatibility
Southbridge shouldn't matter as that is the controller for audio.
As the supported intel chipset is listed there should be no conflicts.
Posted on Apr 13, 2008
Anonymous
  • 101 Answers
SOURCE: VIA Technologies, Inc. PC Model KM400-8235
Probably the cables your are referring to are the front bezel USB and Audio Panel connector .If you do not use front USB port on your cab leave it NC .
Posted on May 03, 2008
Anonymous
  • 21 Answers
SOURCE: Intel DP35DP Motherboard spdif connection
Go here for a manual, which may help you.
http://support.intel.com/support/motherboards/desktop/DP35DP/DP_manual.htm
Posted on Dec 28, 2008
Anonymous
  • 81 Answers
SOURCE: i try to reset my bios from motherboard after
the system unit is it laptop or Desktop? if it desktop open it and remove the cmos battery, and turn-on the pc and turn-off it again. then the system unit would reset. if u have any problem you let me know.
Posted on Sep 22, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: hp pavilion pc sd card reader not working i
vista just had a update for the SD card reader. Go to Microsoft website and update the driver. FYI Vista is also known for having some problems with the SD card readers in the past
Posted on Jan 03, 2010
Where do the card reader cable go on an HP Pavilion a350n
Most card readers are plugged into a usb header on the main board.
Oct 04, 2013 | HP Pavilion a705w PC Desktop
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
Memory card reader for hp pavilion doesnt work how do i find drivers or repair
If it worked before and then stopped working all of the sudden, it may be that a Windows Update caused a conflict with the driver software for the reader. Try going to the HP support website and see if more recent drivers are available. Start with hp.com and go to the support section. If it never worked and you think it might be a hardware problem, the easiest solution is to buy an inexpensive USB memory card reader. They're pretty simple to use and there are many kinds available.
Nov 07, 2010 | HP Pavilion a705w PC Desktop
I need the factory recovery discs for an hp pavilion a705w desktop pc.
Mostly your computer manufacturer will have the disk. The recovery disk is also available with the following company
1) Computer Surgeons
http://computersurgeons.com/
2) RestoreDisk
http://restoredisks.com/
Regards
Dec 18, 2009 | HP Pavilion a705w PC Desktop
My hp pavilion a705w will not read 8 gb micro sd cards. I get an i/o error.
you need to get the reset disk for windows or open up the computer and wiggle it
Dec 13, 2009 | HP Pavilion a705w PC Desktop
HP Pavilion a705w PC Desktop\Ethernet Controller driver
obtain the driver from cd/dvd that was included as you purchased your desktop and try to check if the driver supports with the operating system you are using now. for example the driver available in your cd/dvd is only for windows xp and your operating system you are using now is windows vista of course driver not installed. try to download from internet the driver that are suite to your unit model and current operating system this can fixed your problem or else downgrade your os tha can support the driver that are available from your cd/dvd.
Oct 11, 2009 | HP Pavilion a705w PC Desktop
Connect projector to HP desktop
If you are attempting to connect an LCD projector to a laptop,you connect a monitor cable to your video card and the other end to the monitor input connector. You may have to use an adapter, I know on my LCD projector I had to use a DVI to VGA connector.
Can't say much more not knowing if you are having a problem with a particular brand of projector
Sep 21, 2009 | HP Pavilion a705w PC Desktop
We have an Hp computer. The memory reader in the
Hi Larry,
There are a few likely scenarios that would cause your card reader not to work.
1. The cable inside the computer that connects the front-panel card reader to the motherboard has come loose. You can check inside the case to make sure the cable is tight and connected. You should do this with the computer turned off, and turn it on when you're done.
2. The card reader itself has gone bad and stopped working. If this is the case, you'll need to either contact the manufacturer for repair, or you can go out and get yourself an external USB card reader for cheap.
3. The card reader is functional, but there's something wrong in the operating system that prevents the cards from being read, because the operating system doesn't know how to address the card reader. This can usually be fixed by re-installing drivers and software for the card reader.
May 18, 2009 | HP Pavilion a705w PC Desktop
Blank Picture
Please try to open the casing and then try reinserting the memory and also the video card.. sometimes that problem can be resolve using that solution.
please tell me if what ever happen.
melnavz
Feb 04, 2009 | HP Pavilion a705w PC Desktop
Televison & Video Logo
1,506 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
