HP Business InkJet 2800 Printer Logo
A
Anonymous Posted on May 08, 2010
My HP Business Inkjet 2800, won't print PDF made
My hp Business Inkjet 2800 won't print pdf made from a scan or fax to email page it will print pdf's made from a vector based program... The following prints on the page:_ Error: Typecheck Offending command: Image Stack: 1.0 -mark- -savelevel- -mark- -savelevel-
2800 HP business inkjet won't stop initializing after installing print heads
BECAUSE IT CANNOT FIND THE PROPER HARDWARE AND INK. TRY TO PRINT A TEST PAGE, AS WHEN YOU FIRST TEST IT.
I cannot figure out how to scan multiple pages into one document using my hp envy 5530 and then send them in my AOL email as an attachment
I do this by:
1. Scanning each document and printing each one to a pdf file (using the free doPDF prgrame from http://www.dopdf.com/)
2. Merge the individual pdf files into one pdf file using PDFtk (from http://www.pdflabs.com/tools/pdftk-the-pdf-toolkit/)
3. send the merged file
Hope this helps.
HP 8500. Where is "fax log" ?
PDF Manual at the link below.
http://h10032.www1.hp.com/ctg/Manual/c01643304.pdf
Pages 103 & 104 detail how to print and view the fax log.
Please leave feedback rating.
Cheers
Andy
1helpful
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
[email protected] (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
2helpful
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Troubleshooting
reinstall ur printer software andb then check
Hp business inkjet 2800
Sounds like your driver is sending A4 size documents, and you've got Letter in the drawer. When you do that, it runs out of room on the Letter-size page, since A4 is a tad longer, and has to continue onto a second page. Margins being what they are, the second page is usually blank.
Hope that helps.
k24674
Grand Canyon Tech
Grand Canyon Tech
