Question about Jenn-Air JES9860 Electric Kitchen Range
I have a jenn air electric downdraft range. The problem is we set it for 350 and bake and it wont reach the the 350 level. It did make it to 300 but that took quite awhile.thank you for any help you can give me.
  • Jenn-Air Master
  • 43,501 Answers
If your electricI have a jenn air electric downdraft range. The - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
Jenn-air
What is the complete model number of your unit?
Dec 04, 2012 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
When baking a cake or bars the oven is set to the recommended temperature and baked for the recommended time and the middle doesn't bake all thru.............gooey.
Put a thermomiter in the oven and set oven to 350. Once oven says it has reached temp. Give it about 15 min and check the thermomiter you placed in the oven to see if it maches.
This is where I would start.
Jan 11, 2010 | Jenn-Air JJW8230D Electric Double Oven
Jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Jul 03, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I HAVE A JENN-AIR SVE 47100 IT STARTED TO PRE-HEAT AND STOPPED AT 140 DEGREES NOW IT WONT GO OVER 100 DEGREES BROIL OR BAKE ELEMENTS NEITHER IS GETTING HOT CHECKED HI LIMIT IT'S OK NO TROUBLE CODES JUST NO...
Probably relay control. I have similar problem.
Best estimate I have had is $300, relay control circuit board, Part #12001689 costs $225.
I am getting a NON Jenn Air. Repair record not so good.
Check Consumer Reports
Feb 26, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn Aire SVE47100 that keeps beeping
my stove did the same thing. I turned on the downdraft fan and it quit. I think it overheats the board when you are baking. try it and see if this helps.
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JES9860 Electric Kitchen Range Logo
188 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
