Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Since we bought this television in 2006 the picture just goes out and when we called Westinghouse they said unplug it and then plug it back in. So we would do that and then it would work. Yesterday it went out while watching it changing the input to put in a dvd and nothing will make it work again? Can it be fixed?
  • 11,361 Answers
Most common failur in this TV is the power supply module and the backlight inverter module. At this point you need to check and see if you do have 5vdc standby voltage at the power supply module. It is very cheaply made TV.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
Posted on May 19, 2010
Tv has no picture only sound
the inverter is the usual cause of that issue, some westinghouse models have the inverter combined with the power board. You can get the replacement board and free tech assistance from www.tvrepairworld.com
May 16, 2012 | Westinghouse Electric Televison & Video
Since we bought this television in 2006 the picture just goes out and when we called Westinghouse they said unplug it and then plug it back in. So we would do that and then it would work. Yesterday it went...
Your problem is a common one with these sets and can be as simple as a single component that fails to an entire board that needs to be replaced. The symptom of no picture can be due to a number of different things. WIthout seeing the actual set and taking measurements inside, it is difficult to determine the exact problem.
As far as terminology:
The inverter is a circuit that will generate the high voltage required for the "backlight". The backlight is essentially like a flourescent light that sits behind the panel. LCD TVs work by letting the "backlight" throught the panel. If the backlight does not work, the picture is very dark. You can verify this by using a flashlight across the front surface of the TV. You should be able to see a shadow of the actual picture in the lighted area.
Hope this helps,
Dan
Apr 13, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
LVM-37w1 Westinghouse lcd has picture for 3seconds then goes black but it still has sound i found that if i unplug the inverter from the power board and plug it back in it spikes and picture comes on 3...
Hello, I can assure you it is the inverter board on this unit. The T-CON board (controller) will only mess with your picture in different ways but you the way you describe the symptoms it is for sure your inverter board. The harders part wil be to find some, you should probably look in www.shopjimmy.com, or www.invertercentral.com.
Jan 25, 2010 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
HDMI port not working
I have the same problem - its a HDCP handshake issue. Sony says the firmware in the Westinghouse TV needs to be updated - Westinghouse says that they have firmware updates for some models depending on your TV's serial number, otherwise they are working on firmware updates for the rest of us that should fix the problem. Call Westinghouse to see if you can get updated.
Jul 13, 2009 | Westinghouse SK-19H210S Television
Westinghouse ltv32w6hd power supply
One of two symptoms on this model (LTV-32W6HD) Blue light comes on but cannot shut off. No picture; OR No picture but sound is OK. 1: In both cases replace ALL the electrolytic capacitors onthe output side of the power supply. This should get the power switch to worknormally. 2: Replace the small tiny wee little tiny small 2.0A fuse onthe inverter board labeled F1. This is the small black fuse, not the slightly bigger whiteones labeled F2 and F3.Ta Da...all fixed.
Nov 19, 2008 | Westinghouse LTV32W6HD 32 in. LCD...
Westinghouse LTV-37w2 HD picture malfunction
Have the same problem, have found others too, but no solution yet...
Jul 15, 2008 | Televison & Video
Picture clarity
Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
Feb 03, 2008 | Westinghouse LTV-37WI 37 in. LCD...
Westinghouse LTV-46w1HD
The conversion board on the TV is iffy at best, to replace it is about $169 available cheapest at cfusion.com
Dec 25, 2007 | Westinghouse LTV-46w1 HD 46 in. LCD...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
103 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
