Question about ViewSonic VA1912w 19" LCD Monitor
Flashing and rolling lines on desktop screen and speaker quit working at same time?
  • 11,361 Answers
It may have the same problem (bad caps with bulging tops) just like other VIEWSONIC as shown in my albums here.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 08, 2010
The speaker on toughbook CF-30 quit working when I pressed function key and f4
If you have the speakers on and at the same time plug in a head set, the head set overrides the audio output. Make certain the Audio OUT is clear. Look to the Speak setup at the lower right desktop screen. Right click and check the Volume and Settings. Make adjustments from there.
Jan 07, 2014 | Panasonic Toughbook CF-30 Notebook
Flashing magenta screen, blue screen and shutdown
Your screen is bad more than likely. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad. If the Borrowed monitor displays the same as your original monitor, then the Video Card inside the computer is bad.
May 23, 2012 | Dell XPS 410 PC Desktop
I have a standard old Dell desktop, I hooked up a set of Creative T7700 speakers, they worked wonderful for about twenty minutes and the quit all together. I re-hooked the single line back to the flat...
By the single line I assume you mean the green line out cable and you have connected this to the sound connector on the monitor, so that you have the Dell computer using the monitor speakers?
The problem may be down to the sound chip on the Dell conflicting with Creative labs speakers, it may not support the 7:1 sound. You can try updating the Dell sound drivers, however Given the problem, I'd invest in a pci soundcard and hook the speakers up to that, or look at an external soundcard
Jul 28, 2011 | Computers & Internet
My mtx jackhammer amp recently stopped working and I don't konow why. The light with a lightning bolt is flashing and i lost the manual so Im not sure what that means.
It means that there is a wire shorted somewhere on your speaker wires. Or you could have blown one of the speakers. Disconnect your speaker wires one at a time. When the light quits flashing then you found your problem.
Sep 14, 2010 | Car Audio & Video
Common failure in the VIEWSONIC monitors are caused by bad caps in the power supply, please see my pictures here so you will know what to look for inside.
Please post back so it will help other people also.
Apr 09, 2010 | ViewSonic VA1912w 19" LCD Monitor
Horizontal flashing line at the bottom of screen
I am sorry but, usually, that is the start of the screen's LCD failing, it will most likely get worse over time... This is caused by the "Driver" transistors failing....
Mar 07, 2010 | Compaq Presario Notebook
Speakers quit working
Are you on a surge protector? If not, you should be. Your speakers or sound card/chip is probably fried. 1. reload drivers 2. try another set of speakers 3. get a new sound card one of these will work
Jun 04, 2009 | E-Machines eMachines Desktop PC
Rolling lines on computer screen
To isolate the issue i recommend to connect the notebook to any external monitor and check whether the display is good or not......If the display is good on the external monitor then u need to fix your computer monitor by local service center.
May 05, 2009 | Computers & Internet
Pink & fuzzy bottom screen
I have a new screen that I will put in it for $24.
ninja_freak318@hotmail.com
Dec 13, 2008 | Nintendo DS Lite Console
Rolling horizontal line on screen
What was the reason for aquiring a new monitor?
Nov 23, 2008 | LG Computers & Internet
ViewSonic VA1912w 19" LCD Monitor Logo
107 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
