Erratic volume from new turntable thru used amp
Just bought used amp. Volume fades then comes back by itself. Sometimes happens every few minutes. Sometimes no problem for 1/2 an hour or so. Sometimes some static . Only two front speaker channels work. Turntable and speakers work ok with a different system. Turntable is only component connected to amp.
  • Audio Player... Master
  • 5,190 Answers
First detirmine if it is only the turntable that is causing this problem, by connecting something else to another terminal. If that works fine it will be the cartridge preamp that is causing the problem. From what you describe it sounds like an IC that is playing up.
If the other device plays up as well as the turntable, I still suspect an IC, but this time in the main pre-amp. The reason I suspect an IC is that by the sound of things both channels are playing up and therefore it has to be somepart that has both channels going in and out of it- thus IC!
Posted on May 10, 2010
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: erratic volume from new turntable thru used amp
Glad to hear you got things worked out
-Scott
Posted on Apr 18, 2010
JVC - Turntable - QL-F4 - Noise coming from the motor ?
You don't say whether your turtable is grounded by a separate wire but in some cases grounding is necessary to eliminate hum.
Feb 25, 2014 | JVC Audio Players & Recorders
Just bought a new Shure high performance stylus for my Technics SL-1200MK2. After a few weeks of use, while a record is playing the volume on the left channel will drop significantly. If I take the...
it could be two things:
1.the tone arm wires that connect to the head shell (blue-red-green-white i think)
2. the needle arm has twisted round
Put it on the other deck if you've got one & see if it does it.
look right at the end of the needle tip,& see if it's straight & pointing down, if not carefully twist the needle arm round until it is,& push it into back in to the cartridge a little bit.
Sep 30, 2010 | Technics SL-1200MK2 Turntable
Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
May 24, 2010 | Televison & Video
Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
Receiver fading in and out.
I want to think about this for awhile but first I want to caution you to NEVER turn the volume all the way up and then place your ears near the speakers for diagnosis of an unknown problem. If you inadvertently affect it to come back you can kiss your speakers (and maybe your ears) goodbye.
I'd agree that it is none of your hardware if it affects all inputs, two receivers and multiple speakers.
This sounds like a good one.
The simplest source to use for further trouble-shooting would be FM as it has no external connections, and it's vanilla stereo. Keep It Simple.
"Power bars"? Do you mean like a power strip with multiple outlets and maybe some kind of surge protection? Pare the system down to its most basic form - receiver, front speakers, one power source direct from the wall. What happens? Add components and complexity until the problem returns. Good luck.
Jan 22, 2010 | Audio Players & Recorders
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Oct 05, 2007 | Car Audio & Video
Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Aug 24, 2007 | Technics SA-DX940
Speakers fade in and out when listening to music
ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
May 25, 2007 | Dell 5650 Computer Speakers
55 people viewed this question
 Grubhead
Grubhead
