Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox I have the same problem and need to know if you know the part number for the sensor
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Posted on Apr 10, 2008
SOURCE: Maytag Skybox MBV1976AAB Compressor Start Relay
I just read another post on a different site from someone who said they were able to pay $160 for a refrigerator technician to come out and replace the compressor and install 2 additional fans to help prevent overheating. I'm going to look into this, otherwise off to the dump. Had ours for over 2.5 years and it just stopped cooling last week. Bunch of warm beer and sodas in there now...upsetting, but what do you expect when everything is made in China these days. Our country has let itself down for letting quality manufacturing give way to cheap labor.
Posted on Dec 23, 2007
SOURCE: maytag skybox schematic
there is a basic schematic on the back of the unit
Posted on Apr 30, 2008
  • 3 Answers
SOURCE: Maytag Skybox dispenser
I also have one of these vending machines. The problem Maytag had with these and the reason why they are discontinued is that it was not made with an automatic defroster. SO, ice litterally builds up on the entire motor in the back and then the buttons do not work. Here is an easy test. Unplug the machine for 24 hours and if there is ice on the motor it will melt off(to where I dont know!!). Try the buttons again and see if they work. Mine did. They also had to come out and replace one of the pieces inside because the ice broke it! Mine by the way does not work anymore because the other problem they have had with these is that the compressor goes bad!! Once THAT happens, its more expensive to fix than it's worth! Good luck! Maytag SUCKS!!!
Posted on Nov 13, 2008
  • 44 Answers
SOURCE: maytag skybox not cooling need name of place and
before replacing parts. unplug it and from back and under neath get all the dust out,best to blow air in there to remove dust than plug it back in and leave it on number 3 setting for 6 to 8 hours than if cold you can adjust the settings.
or part location is at www.maytage.com/skybox parts
Good Luck Im pretty sure you won't need to buy part's after air cleaning
Posted on Apr 08, 2010
Testimonial: "`will try it and let you know.....thank you very much,,,,,,"
  • 59 Answers
SOURCE: The part I need for my Maytag Skybox is NO LONGER
REMOVE 3 WIRES ON SMALL BOARD RIGHT AT BOARD SURFACE. LOOK FOR END WIRE WITH X PRINTED ON IT ,PUT OFF THE SIDE. YOU WILL NOT USE X WIRE. SKIN CENTER WIRE AND END WIRE , THESE ARE WHAT YOU WILL HOOK UP. DO NOT TOUCH 2 OUTER WIRES THESE ARE DEAD SHORT. IF YOU DO NOT SEE X ON WIRE DO NOT WORRY CENTER WIRE AND 1  END WIRE WILL NOT SHORT. JUST BOTH OUTER WIRES DO NOT CONNECT. GET SET OF RADIO SHACK WINDOW ALARMS MEGNETIC CLOSE AT CONTACT. SILICONE SCREW TERMINAL MAGNET TO UPPER RIGHT SIDE SOLID DOOR EDGE AND OTHER MAGNET TO UPPER RIGHT FLAPPER DOOR ABOUT 1 INCH FROM EACH OTHER DO NOT USE SCREWS. REMOVE DOOR AND LAY FLAT IF NEEDED. THEN HOOK UP 2 WIRES AS DESCRIBED. IF YOU ARE NOT SURE OF 2 WIRES HOOK UP MIDDLE WIRE TO EITHER OUTSIDE WIRE ONE WILL WORK AND ONE WILL NOT. AFTER SILICONE DRIES HOOK UP WIRES . NOW YOU HAVE A WAY TO RESET  CYCLE , IF YOU USE GLASS BOTTLES YOU MAY NEED TO HOOK UP NO-NC 2 TERMINAL WITH COMMON TERM. SWITCH.
Posted on Apr 20, 2010
Maytag skybox not cooling need name of place and parts number for serial 10170778EJ. Model MVB1976AAB
Apr 08, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from maytag skybox machine
Maytag never offered a compressor as a replacement part for the SkyBox. It simply was not cost effective. If you are sure the thermostat is supplying 120VAC to the compressor, then have a qualified service technician install a Supco URCO410 relay/capacitor/overload kit on the compressor. As with any sealed refrigeration system, the US Environmental Protection Agency requires that a certified refrigeration technician recover the refrigerant charge before accessing the sealed system.
I hope this helped.
Maytag skybox dispensing chut
well, the middle 2 chutes are not the same part number as the top or bottom...what is the part number of your assembly? where are you located?
Nov 03, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox
Go to www.apdepot.com and enter your model number under Brand :Maytag you will see a parts breakdown and you can buy it online
Oct 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox
Ours did the same, door flap sensor got wet from condisation and fried it. If you find parts let me know, it's happened again.
Oct 11, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Broken Door Hinge
go to www.apdepot.com enter your model number and a parts breakdown will come up you can order parts and they will ship to you
Sep 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox parts
you need the numbers off the compresser to get the BTU of it before that question can be answered. But your right this is a non replacement part (you cant buy it) it may cross but need cooling capacity first
Jul 28, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Compressor
cant replace it it is a thow away model go to www.apdepot.com do a search for your model you will see here is the Service Manual check your email
May 05, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
565 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
