Question about Hammering
My breaker seems to get hot and smokes and sparks
My breaker seems to get hot and smokes and sparks but it does hammer !!! any ideas why ??? could dampness cause it?
  • 2,176 Answers
Not that I would think, you have either an electrical or bearing problem. If you can remove the cover where the brushes are look at the condition and length and also look at the commutator for discoloration between the bars. It sounds like you need to take motor apart before it causes major damages if not already
Posted on May 08, 2010
Started smoking from trigger
Maybe there is a interference suppression capacitor for radio supression near the switch have to only remove it . i do it by the most Bosch powertools because it made more problems than the purpose for which they are.
The ultra short wave radio listeners are not much more today everywhere its DAB+ do not suffer
Apr 07, 2014 | Bosch Brute Breaker Hammer 11304
While baking there was a spark and smoke that blew out the breaker
Sometimes there are two breakers, one for the 110v and one for the 230v. The 110v works the light and the clock and such, and the 230v handles the heater elements. If the breaker blew, you might need a repair though. Also always be careful when working with electricity please.
Dec 20, 2011 | Frigidaire Kitchen Ranges
Had low battery...charged and re-installed. wire running from positive to circuit breaker started to smoke...now I have no juice when I turn on the key..I pulled the circuit breaker and tried to short to...
You've got a dead short somewhere. First test everything you can with an ohm meter. Pull all the fuses out and measure the resistance from the circuit breaker ot ground. Check the outer case of the circuit breaker as well. I have seen them go bad and create a short circuit themselves.
Good Luck
Steve
Feb 27, 2011 | Harley Davidson FXDX Dyna Super Glide...
Bosh Brute jack hammer It does not hold chisel bits when locked in.
I have a rockworth arpd 1700 breaker and need new points and chisels any idea where i can get them from ive looked every where.
Oct 17, 2010 | Bosch 11304K Brute Breaker Hammer
How do I drain the gear oil from a Bosch Brute Jack Hammer
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Changed spark plugs because of misfire. now when
seems like you are leaking antifreeze inside your engine have it checked white smoke usually means antifreeze
Jan 10, 2010 | 1997 Mercury Sable
Hammer sparked and smoked and blew breaker. New brushes were installed. Still sparks and blows breaker
DO NOT OPERATE IT YET!!
the 99% problem is in the armature.it has a burned rewind coil on it.do not use it not to make the other rewinded coil on system will be burned.Replace the armature,or you find a shop which have an specialist in rewinding electrical motor works..if it can be rewinded.
Nov 11, 2009 | Measuring Tools & Sensors
We have a couple of brutes that hit slow, I've tried rebuild kits, field coils and armatures. None of these seem to work. Amp drawn normal. Any Ideas???
Sounds like you have too much suction in the hammer cylinder. The hammer may be getting stuck at the top of the cylinder. Inspect to see if the hammer beat piece will slide out of the hammer cylinder. There may be too much grease behind the hammer causing suction at the up stroke. There may also be scarring inside, so inspect to see if the hammer beat piece slides smoothly. Hope this helps.
Jun 26, 2009 | Bosch Brute Breaker Hammer 11304
Hammering Logo
141 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
