Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
  • 12,061 Answers
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
Posted on May 08, 2010
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
I bought a Toshiba 32 Inch HD Ready Digital LCD TV - 32BV500B yesterday from Argos, Leyland. I tried to set it up and it searched for programmes but did not return and any programmes. It had a blue...
Are you using the freeview tuner, I only ask as it looks like your having a similar problem that I had a few months back. I moved into a new house and plugged in the tv. Using the freeview tuner I wasnt able to get any channels. It turned out although the aerial picked up regular analogue tv it wasnt the correct aerial for freeview.
Aug 17, 2010 | Toshiba Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
Thomson dti6300-16 won't record freeview channels....
maybe a defragged hard drive follow this procedure:
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Oct 02, 2009 | Arris DCT2608
Similar problem
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Oct 01, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Retuned my Freeview receiver but now have black bars.
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Sony BRAVIA KDL-40V4000E 40 in. LCD TV
My freeview needs retuned
If it is built in. Do the following.
Press the button on your tv remote that says TV/DTV.
Make sure it says DTV on the screen normally at the top corner of the screen.
Now with the Tv remote press the menu button. you should now see a menu appear go down to Auto Tune / Auto Store and press select or enter. T
his should now start searching through for you Freeview Channels. Dont be alarmed if you dont see many channel appear at the beginning of the scan as it normally goes past 75 % before they start filtering through.
If your box is a standalone then Just use the Freeview box remote and then press the menu button. go down to Install. this would then prompt if you would like to do a full search or add channels. I would do full search this will Delete all the channels previously installed and search from scratch.
I hope this sort out your Freeview
Little Dish Fitter
Sep 22, 2009 | Samsung Televison & Video
Cant retune my digtal freeview as my picture keeps freezing
Jun 02, 2009 | Samsung HL-S5086W 50" HDTV
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
DO NOT PRESS OK WHEN ASKED TO UPDATE SET TOP BOX.
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | Televison & Video
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
