Question about Bauknecht 24 in. GSF8971 Built-in Dishwasher
Dishwasher stops after a couple of minutes and F4 shows on the display
  • 12,061 Answers
the F4 problem in the Dishwasher is common, and the solution is often to replace the Water Indicator unit. This is because the light-action microswitch attached to the unit often loses its spring.
Replacement is HERE if required.
Also, dismantle the sensor unit to get all the "gunk" out. There can be a carpet of white goo covering the rubber diaphragm, get the thing out of the machine though the front bottom inspection cover.
Posted on May 08, 2010
Does anyone know what the F4 fault is on my kitchen aid dishwasher? I can reset it and then start over or select another program, although after approx 1 minute the F4 error code comes up and I cannot see...
Check the drain hose. When you turn on a dishwasher, the first thing that it does is check the pump. If there is a drain issue then it stops.
Mar 02, 2014 | Dishwashers
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Program shows shows f4 and peeps
F4 indicates
DRAINING FAILURE
drain pump starts and after 4 minutes the OWI detects that mashine is 'not empty'
posible mailfunction reasons:
drain pump defective/blocked
siphon closed
control board defective
OWI defective
OWI - optical water indicator
remember to unplug it from power if any repair is done
Best regards and good luck
Oct 04, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Fisher & Paykel Nautilus Dishwasher
F4 is a fault code telling the controller that the water is not heating up. This can be caused by either a faulty heater plate, a bad connection between the plate and controller, or the controller itself. If you wish to fix this yourself, changing the heater plate is a fairly involved repair and should be done by someone with a high degree of mechanical ability.
Dec 09, 2008 | Dishwashers
What is F4 error on fisher paykel dishwasher?
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Oct 29, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
CODE F4 and washer not working
Not too sure on that code, could be timer error. One thing to try would be to turn off the AC power to the unit and let it stay off for 15-30 minutes and then turn it back on. Sometimes if the unit takes a voltage spike it hashes the memory and resetting the power will clear it up, but to do this the voltage needs to turned off at the fuse/breaker box and not just the switch on the front. If you have the manual it may give ideas. I could not find the model no. you listed. Check to see if it is correct if resetting the unit doesn't help.
Feb 01, 2008 | Whirlpool 24 in. ADG6962iX Built-in...
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Bauknecht 24 in. GSF8971 Built-in Dishwasher Logo
866 people viewed this question
Top Bauknecht Dishwashers Experts
freddyfox
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
