Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
Hi i have a 431 and its have trouble starting the fan starts ok but when it comes to start clicking to egnite the gas it only clicks once or twice but wont fire the gas up but the gas i can hear comeing out any hints thanks Glen
  • 12,061 Answers
Http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/550.pdf
above is a service manual, it will help toy troubleshoot and hopefully repair your unit. Be careful, if in doubt, call a certified gas fitter.
I would suspect, the thermostat, or some other sensor, as this is usually what's wrong.
Posted on May 08, 2010
Testimonial: "thanks ill check it out"
Blower motor neads to b replaced
Posted on Aug 30, 2010
7 flashes no ignitor
Check spark wire if OK bad module
Mar 28, 2014 | Coleman Propane Forced Air Heater...
Whirlpool fridge freezer
Totally a normal action.. When the compressor switches off once the temperature is reached, or possibly after a defrost cycle, if the gas hasn't quite equalised, it will click once or twice then start up.If the compressor has a starting capacitor and it does the clicking, then one needs to check the capacitor.
Sep 22, 2013 | Freezers
Card started making loud clicking noise i have tried blowing dust out of it when i start my computer within a few minutes clicking starts again
Hi, couple main reasons to get loud clicking in a computer. First is the hard drive, so if you can turn the system off and disconnect the power and the information cable from the hard drive, yes your computer will not boot all the way back into windows but that is ok since you just want it running for awhile to see if the clicking stops. Next thing would definitely be the fans, any fan in the system, the blade part of the fans can get loose sometimes and start to hit the sides as it spins around, you need to be sure about which part it is that is causing it, it can come from the power supply fan, the case fan, the video card fan, the cpu fan, and you might have more than one case fan, test by disconnecting one at a time just make sure to disconnect the device too so you do not over heat anything. Once you identify which fan just replace it, if its something like power supply or video card, unfortunately you might want to look into either warrantying the part or buying a new one.
Nov 01, 2009 | PNY GeForce 9800 GT, PCI Express Video...
I posted this a little bit ago but forgot to mention The car would not crank. I started the car and it just dies. Wlould not start or even crank. When I put the key in the egnition (and NOT turning the...
check to make sure yu have 12v at the battery, once you do turn the ignition to start, if nothing, check the fuse and relays that control ignition, if all is good then the click sound is coming from the starter, have the solenoid replace.
Jul 31, 2009 | Saturn SL Cars & Trucks
I started the car and it just died. Would not
you may be out of gas or have a bad fuel pump
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Having Trouble Starting up G37
For about 2 wks ive had some trouble starting my Infiniti G37. every once and a while when i start up my truck it had some trouble but it would eventually start. it would only take me about once or twice to start it. i thought it was a cold engine problem. but now the ****** wont even start at all. all i can hear is the clicking noise. i know its not the battery cause it shows it is pretty well charged on the instrument panel window when my truck is actually running. so not being much of a gearhead can anyone help me out. is it something i can fix without getting any parts? or am i doomed to being a whole new starter. btw it started today with the help of jumper cables. but like i said i dont think its the battery but i can be wrong.
May 14, 2008 | 2008 Infiniti G37
Printing job stuck in spooler
3 possible fixes: 1. click Start>control panel> Performance and Maintenance> Administrative Tools> Services> Print Spooler to open the options and ?stop? to stop the spooler. Once its stopped click start to start it again. Ok to exit. 2. click Start>control panel>printers and faxes. Choose the 5510 icon. Right click and then >properties>advanced tab>print processor and choose the RAW option. Click apply to exit, ok twice, and restart. 3. reinstall the driver. http://h10025.www1.hp.com/ewfrf/wc/ softwareList?dlc=en&lc=en&product=311255&lang=en&cc=us&os=228 Good luck
Feb 21, 2006 | HP Officejet 5510 All-In-One Thermal...
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
492 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
