Question about Stokke Sleepi Bassinet Crib
How do i attach the bumper to the cot. It doesn't seem to fit at all. Seems loose and doesn't fit over the parts of cot that join together
Dehumidifier pump leaks
Try some teflon tape to tighten things up?
Aug 28, 2017 | Dehumidifiers
Air just blowing through and out the top discharge valve
Air leaking from top of nailer is indication of bad cylinder seal. Remove cap and look for loose fitting or broken cylinder seal (vinyl ring). The seal should fit snugly around headvalve. If seal seems ok then remove upper bumper and look for cracks (round vinyl part pushed into center of headvalve). Replace as needed. If all parts look good, and while you have the head valve out, clean the upper head and lube with plenty of silicone paste (sold at Lowes in the plumbing department, used for faucet orings ). Parts are sold at your local dewalt repair center or at www.toolpartsdirect.com.
Jul 31, 2011 | Porter Cable Cable Factory Reconditioned 2...
Mislaid assembly instructions trying to get a email copy if possible for "Adam Cot Bed"
Here you go: http://www.babystyle.co.uk/pdf/CalgaryCotbed_AI.pdf
May 24, 2011 | Toys
I have a second hand Cosatto Norma cot BS1753:1987 & I cant attach the drop down side as we dont have the catches or screws. Cosatto have emailed me saying that they dont have any information on this...
I have a NORMA Cosatto cotbed, and have had it since 1993 when my daughter was born. But it was not new then when my mother bought it. I have all the fixings and screws, but one is broken. I do have a copy of the instructions for the cot but
I can't seem to attach the scanned copy of the instructions, but will try to photograph it and attach it to a second posting to see if it is the same cot.
I have considered selling it in the past, now that it has gone around the family, but had hoped to get a replacement screw before selling, but got the same response from Cosatto.
Jan 24, 2011 | Baby Gear
I would like the mamas and papas lucia cot assembly instruction as I have misplaced my own...I need to change the cot to a bed, but it dosnt seem to go together, as if some parts are missing....Thanks
Hi.
To get new Mama and Papas mode instructions you need to contact M&P, contact is in their website.
To assemble the cot I suggest using the instructions for the Amera model available here: Click here.
Regards.
Oct 07, 2010 | Toys
Upper spray arm failure
Easy to solve!
(1) Remove the drawers to give yourself room to work
(a) bottom drawer just comes right out -- but you knew that
(b) Carefully unclip small plastic retainer caps at the ends of the metal "glides" for the top drawer. Then slide the caps out of the glides. Then remove the top drawer.
(2) Unscrew the "gear-like" plastic fitting into whose hole you were sticking your finger when you felt that small cylindrical ring.
(3) Now that you've got access to the ring, the solution is obvious -- use it to snap the upper arm back into the gear-like fitting. When you're done, the arm will rotate freely in the fitting.
(4) Put everything back together and enjoy the fact that you didn't have to pay some yobbo $75 to come to your hous and do this for you!
(HINT: When screwing the gear-like fitting back into place, use the old machinist's trick of pressing gently and screwing backwards until you feel a click. The threads will now be aligned for you to screw things together the right way. If you do not do this, you might experience frustration reattaching fitting -- since the piece it screws onto is spring loaded.)
Dec 06, 2009 | Frigidaire PLD4555RFC Dishwasher
The on/off slide mechanism doesn't work.
If you are good with fixing things you can take it apart and see if you can reposition the slider switch to original condition. The little rubber plugs or bumpers has screws under them for the case. You will need a decent small screw driver to remove these screws. Just remember how the parts fit together and when you get the screws out the case can be gently pried off. Again, you will have to know how it fits back together again, but it is not that hard to do. The slider is either worn, or popped loose from the body of shaver. You can look on ebay and find a replacement shaver for cheap.
Good luck
Aug 29, 2009 | Braun 8585 Electric Shaver
Quinny 2006 Dreami Cot
The US distributor for Quinny Strollers is below. They may cary the part you are looking for as well...
Dorel Juvenile Group USA
Canton Commerce Centre
45 Dan Road
Canton, Massachusetts, USA02021
(781) 364-3100
(800) 544-1108
Mar 24, 2009 | Quinny Buzz Jogger
ASSEMBLY
I just had to repair one of these guns for work. It's a bit tricky, seeing as you are dealing with springs and such...but it can be done. Take your time ...don't set the springs until you have things set in place and lined up. Make sure the pins are in place. Set the flat spring first (it is the toughest) while the handle is depressed all the way in. Gently open the handle and then set the torsion spring. Take your time here...springs are set and they could make all the pieces fly out if you don't quickly get the other half put on it. Hope this helps.8d59edb.jpg
Aug 21, 2007 | Black & Decker 5700 Powershot Forward...
Stokke Sleepi Bassinet Crib Logo
127 people viewed this question
Top Stokke Baby Gear Experts
Douglas Dinnebeil
Douglas Dinnebeil
Don A
Don A
Are you a Stokke Baby Gear Expert? Answer questions, earn points and help others
