Question about Lexmark Wheelwriter 1500 Typewriter
Correction tape not working
We don't use this machine very much and today the correction tape is not working. We changed to a new cartridge but it still won't work. Does it dry out?
  • Di_wk Mar 27, 2008
    We tried new tapes but it is still not working.
  • Lexmark Master
  • 3,594 Answers
The ribbons and lift off tapes both get old and change composition, get a fresh ribbon and L/O tape then try it.
DickyO
Posted on Mar 27, 2008
How do i change the correction tape
tHE CORRECTION TAPE CARTRIDGE JUST CLIPS ONTO THE BOTTOM OF THE RIBBON CARTRIDGE. THERE IS A CATCH/RELEASE LEVER ON THE FRONT OF THE RIBBON CARTRIDGE.
Sep 06, 2012 | IBM Lexmark 6781-024 Wheelwriter 1000...
Changing correction tape in model SL 105 I am attempting to put in a new correction tape in my Model SL 105. It appears to be moving, but I am getting no correction.
If the correction tape is moving and lifting there is a good possibility that the ribbon or correction tape are old and have changed composition or you have a non correctable ribbon.
DickyO
Sep 21, 2011 | Smith Corona Office Equipment & Supplies
Just started using a Smith Corona SL 480 in church library. Bought new ribbons and correction tapes. Ribbon cartridge went on just fine but I can't figure out how to install the correction tape. It...
I found a manual for a different model Smith corona which may help. Is sounds like the correction cartridge needs to go in first. Here is the link to the manual and best of luck to you.
http://www.smithcorona.com/pdf/Office2000/Office2000Chap7.pdf
May 09, 2009 | Office Equipment & Supplies
CORRECTION TAPE
correction tapes will not work with multistrike ribbons. You have to use a correctable ribbon. If you can find a white out tape, it will work with multistrike. What model typewroter do you have?
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correct key
Jul 07, 2008 | Brother ML-100 Typewriter
Correction tape problem IBM Selectric II
Take off the ribbon, just inside the rt. side frame of the printer is the mech. for L/O feeding. There is an arm that moves back and allows the feed to ****, that mech. is probably gummy, lube with some WD40 on both sides of the printer (the left side sets up correction lifting.
DickyO
May 19, 2008 | Lexmark Wheelwriter 15 Series II...
Correction Tape
Is the ink cartridge correctable ( yellow or orange core) not nultistrike (blue core) ?
Aug 29, 2007 | Brother EM-530 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
