Question about Electronics - Others
Cant get sony shelf system to work
Have wired shelf system together but the graphic equaliser lines are all flat. Result no sound from speakers
    Sergeant:
    Champion:
  • 236 Answers
She is dead take her back
Posted on May 08, 2010
I have pioneer sx 20 tuner/amp and behringer ultragragh pro fbq 1302 graphic equaliser linked together with mono cables via tape i/o rca ports lights on graphic eq lights in sync with sound on sliders but...
It is a bit fuzzy for me, how everything is connected, but just plugging in cables where they fit won't always work. Special not with tulip plugs and cables.
Not sure you Amp has speaker switches, but you could start there. NEVER switch on an amplifier, while the volume button is open. Not even when it is half way. Please every time you want to change something, first lower the volume.
First try to get any sound from the amplifier in the speakers. When you have something like noise in the speakers, then you can test an input on the amp. You could put in a pice of wire in and choose the correct input button and then turn up the volume.
If it starts humming, you are on the correct input. On that input you plug in a device giving enough power (voltage must be within the range for that input) and check if it works.
When you want to know anything about voltages going in an amplifier I add a wiki page, and for all other inputs you can find the levels on Wiki too.
Line level Wikipedia the free encyclopedia
Jan 27, 2015 | Behringer Audio Players & Recorders
I cant get "PROTECT" off my Sony MHC-EC909iP Mini Hi-Fi System.
Disconnect the speaker wires from the unit. If it still says protect when you turn it on, then the amp ic has been shorted and needs to be replaced.
Feb 12, 2013 | Audio Players & Recorders
I have sharp cd pc3500 stereo system when i turn the power on the message on the screen shows PROTECT. I cant do anything nor any function work
Make sure the speaker wires aren't shorted together and that they are not freyed or cracked...the unit is in protect due to it's internal circuitry sensing a shorted output condition...this is in place to protect the unit should the speaker wires become shorted together. You can remove the speaker wires entirely and then turn on the unit to see if it comes on...if so then I would look at each wire carefully to make sure they look good..of course if the unit comes on and the wires look good then you may have a bad speaker component...Now, if the unit stays in protect after you unplug the speakers, then the unit probably has a blown audio output stage inside the circuitry and will need to be serviced.
Jan 05, 2011 | Sharp CD-PC3500 CD Shelf System
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
I cant find the operators manual for Panasonic audio rack system
 http://service.us.panasonic.com/operman/findmanual.aspx?cat=AUD
This link is for multiple Panasonic sound devices.  I am not sure whether your models are on here, but have a look.
Apr 06, 2009 | Panasonic Audio Players & Recorders
Power shuts off when CD/tuner/Tape Button is pressed
take out any extra speakers unplug and replug,and if problem continues your fuse is broken.
Apr 02, 2009 | Sony MHC-GX450 CD Shelf System
Sony lbt v702 hifi system stack
i have a sony stack system i had put away for a couple of years, i have now put it back together, but when i wire both speakers up, the sound go s to a point then cuts out, whith a mesage on the front saying protect, it i take one speaker off! nothing happens, can any one help please?
thak you for your time.
Steve.
Sep 22, 2008 | Audio Players & Recorders
Extension wires for speakers
If there isnt a line up the postive, then usually the wire on the inside is a different colour, ie. bronze/copper for positive and silver for neg.
Strip a section from the base and take a look!
Jun 30, 2008 | Sony MHC-GX25 CD Shelf System
How can I make this sound great.
line out from mixer------to crossover in---------crossover out-------to amplifier line in-----------from amplifier out--------to loud speaker.
---from low output(low frequency)of crossover-----to line in in subwoofer.(mixer is ordinary mixer not powered mixer- and in case of powered mixer take care it is line out(0db---to4db)not amplifier out which you connect it to loudspeakers.
May 19, 2008 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
