Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
My computer don't read my samsung mobile device
Plug in
  • 5 Answers
Yh plug it in
Posted on May 10, 2010
Hie,i'm using gt-s5233a so how can i activate my mobile tracker
someone inserts a new SIM card in your mobile
phone, the mobile tracker feature will automatically
send the contact number to two recipients to help
you locate and recover your phone.
To activate the someone inserts a new SIM card in your
To activate the mobile tracker,
1. In Menu mode, select Settings ? Security ?
Mobile tracker.
2. Enter your password and select Done.
3. Select On to turn on the mobile tracker.
4. Select Empty under Recipients to open the
recipient list.
5. Select Add recipients ? Phonebook to open
your contact list.
6. Select the contacts you want.
7. Select a number (if necessary).
tracker,
Mobile tracker.
recipient list.
your contact list.
Mobilepriceshop com Full Phone Prices and Specifications
Jan 01, 2016 | Cell Phones
The touch screen of my samsung GT-3650 is not working at all due to hardware problem in the mobile device. How can I export the data out of the device to a PC?
because this mobile has a single screen which works as touch and lcd also u have to plug in the data cable than computer sync and than u can transfer ur data
Oct 04, 2013 | Samsung S3650 Corby / S3650 Genio Touch...
Micromax x225 is showing low signal
Ever looked at the power specifications of a mobile charger?? well if not, then have a peek... u will read that the output voltage is 5V DC........ the computer USB also has a voltage output of 5V DC........... any USB based electronic device needs this power to get started.... The laptop coolers u get basically work on this power from the USB... U'll notice that the USB ports have 4 terminals.... the extreme outer side are the POWER terminals +ve and -ve..... the middle 2 are the BUS lines IN and OUT.... a BUS is something electric conductive that allows the flow of 0's and 1's or rather high and low voltages to pass(Basic IT theory).... so this 5V DC can be used for doing anything; charging the mobile phone battery to lighting up entire rooms with LED's, making laptop coolers, etc......... Every mobile phone which has the USB connectivity option gets charged when plugged in... so sometimes even if u dont have the Mobile charger dont panic, find a computer and plug in the USB... not only micromax x225 mobile but, there are almost 80% mobiles which charge by connecting it to pc. Only nokia phones don't get charged. it is a good feature don't worry
Feb 24, 2012 | Nokia Cell Phones
Deleting photo's from gallery on a galaxy ace
You may try this mobile phone photo recovery software which helped me before. You may check out this tutorial
Mobile Phone Data Recovery
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Jan 01, 2012 | Cell Phones
I cannot work out how to transfer photos from my Samsung SGH-A412 mobile phone to my desktop so I can print some. I read leaflet, no help. I have plugged in the usb to usb cable included in box. No promps...
By default, samsung phones connects as modem. You have to change the connection type to Memory Card.
Go to settings, connection and Data cable. Change modem to memory card.
It will shows as a removable drive in my computer
May 25, 2011 | Samsung Cell Phones
My phone cannot access the memorycard.
There are so many cases when people can't access the memory of the SD memory card.When you get connect with your system then it may need the driver to recognize the connected device.
The mobile phone comes with a driver or suit any thing which is associated with the mobile phone during purchase.You can install the driver and easily get access to your mobile phone and card memory both.
Some of the mobile phones are not being detected without the proper driver.Samsung D780 drivers
You can access the memory of your card using the provided cable which can solve the problem.Just plug the cable into your phone and another end should be plugged with computer.
Wait for a while if it is not coming quick as you want.If the device is not being detected the you can use the device manager utility of the windows system.
Move to the My computer icon >Properties >Hardware tab> Device manager> .
Check your connected device in the list of Universal Bus Controller and if not find then move to the Control panel and use the Add new hardware wizard.
Another solution is:
Using Card Reader to access the files:
The memory can be accessed with one of the different methods but for this procedure you need to have another device called Card reader which is associated with a cable.
The memory can be accessed with this procedure :
1- Pull out the SD memory from mobile phone.
2- Use the card reader,insert the SD memory and plug this cable to computer.
3- Try to look, if the device is showing in the windows then it alright and your mobile phone has some disturbance regarding detection.
4- Just make the desired operation and if that is not being performed then you have to format the driver,I don't think any options is rest to try.
Oct 11, 2010 | Samsung D780 Cellular Phone
How can i get my camera phone to upload photos on my computer
It is easy to exchange information between your Samsung mobile phone and PC. Nearly all Samsung mobile phones come with PC Studio (which can also be downloaded here:). There are a range of USB connectors for Samsung Mobile phones available if one was not supplied with the model. Check your user manual for more details.
User Manuals & details of accessories are available by clicking on the link below:
Alternatively, many handsets come with microSD cards that some PCs can read. Also some handsets have Bluetooth® connectivity that can be utilised in some cases, to exchange data with compatible device (e.g your PC). Check your user manual for more details.
Hope it helped.
Nov 22, 2009 | Samsung SGH-D900 Cellular Phone
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
Samsung sgh-e900 usb connection problem
hi first things first
the e900 does not use use active sync that software is for pocket pc/pda ect
you need to download phone manager software for the e900 from the samsung site.
hope this helps
Jan 10, 2008 | Samsung SGH-E900 Cellular Phone
Samsung u600 usb connection wizard
PC Studio for Vista can be found on the Samsung Website. Series is "U series" and model, of course, is U600. As for installation, as Samsung suggests, make sure that the phone is NOT connected to the USB port at ANY POINT prior to the completion of the installation. Install the software as normal. Then, after it has finished installing, open up PC Studio and plug in your phone. At this point, the software SHOULD recognize that the phone has been connected after setting it up to use USB connection in the “Connection Manager” (Click “File”, “Connection”).
If it is still not recognizing the device after plugging It in, or if it displays a message along the lines of “USB Device Not Recognized” KEEP THE PHONE PLUGGED IN TO THE USB, Go into the Control Panel in the Start Menu and open up the Device Manager. At the very bottom of the list of hardware etc, there will be a selection for “Universal Serial Bus controllers”, expand this menu and look for an item called something like “Unknown USB device”. Double click on the device and go to the “Driver” tab (I think you have to press a button on the first screen that appears in order to get to the menu driver tab. Although I can’t remember what was written on it, there was only one there). When in the Driver tab, click on “Update Driver”. Now on the wizard that appears, click on “Browse my computer for driver software” then, ignoring the rest of the page, click on “Let me pick from a list of device drivers on my computer”. Uncheck the selection box “Show compatible hardware” and scroll down the list of Manufacturers until you get to “Samsung”. Now, if you’ve installed PC Studio, you should see four separate selections for “Samsung”. Click on the fourth manufacturer selection and you should see “SAMSUNG Mobile USB Device” as a Model selection, select it and click “Next” (If, 1, you don’t see “SAMSUNG Mobile USB Device” at all, then just browse the other three Samsung based manufacturers or, if 2, you have more than one entry of “SAMSUNG Mobile USB Device” then select the top one”. Also, if Windows comes up with any warnings about installing device drivers, just ignore them). Windows will now update the driver (It actually updates three drivers). If you open up PC Studio the phone should now be recognized as connected (Assuming your prior setting up of the Connection Manager to use USB).
Good Luck.
Oct 24, 2007 | Computers & Internet
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
