Question about DFI K6XV3+/66 Motherboard
Please than maximum size hard disk I can install on a DFI mothercard K6Xv3 + ATA66 model. Thanks
    Sergeant:
    Champion:
  • 236 Answers
You can a tetra bite the only thing that will be sacrificed is the speed it can be accesed at
Posted on May 08, 2010
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
Hi There. I am looking for an Internal Hard Drive to suit a Dell Inspiron 1525 Laptop. Seagate Momentus 5400.3 160Gb ST9160821AS. Where can I get one or is there another Hard Drive that would be OK to use...
I suggest you check the specification of your Dell laptop to see the maximum size hard drive it can support. The maximum size hard disk you can install in the laptop depends upon the BIOS.
Any major brand of 2 1/2" hard drive will work with the Dell.
Oct 27, 2010 | Seagate Momentus 5400.3 - 40GB - 5400rpm -...
Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
An alternative -
You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
Hello sir, i am replaced my hard-disk. in that Windows XP not installing. Error has occurred. reply me.
There are 2 issues,
One is hardware and the second is software.
First check if is well installed upon the bios.
Sometime you will need to download third party software(pre-boot bios software) to make it run correctly.
Some model of laptop support small size hard disk.
So you will have to use utility like "ezdrive" or "maxblast.exe" corresponding the make of hard-disk and the model you are using.
Now while installing windows create partition for the operating system separately
Some old version of xp sp2 support 137gb maximum size, so check this...
Cheers
uttam
Feb 23, 2010 | Compaq Presario 700 470024-192 Notebook
How much is the maximum capacity of hard disk in p4vmm2 motherboard
Motherboards do not have hard disks but you can attach hard disks to them. Most motherboards allow you to connect several hard disks of various sizes. Most home computers only have one hard disk.
Open your computer back up look for the hard disk(s).
The capacity of the hard disk is usually on its label.
If not, you can look it up by the manufacturer and model name on Google to determine the capacity.
Depending on the size of the disk, 1 or more GB of the total capacity will be inaccessable because it is used to format the disk. (e.g. Windows might only "see" 28GB of 30GB disk.)
If this helps please vote for my solution.
Dec 02, 2009 | Acer Computers & Internet
SCSI Disk capacity Limitation in HP-UX 10.0
your hard is only 2 gb?so its means that disk full?when you are installing windows xp the minimum capacty of the hardrive should be 3 gb try to look another hardrive!!just try
Jul 14, 2009 | Computers & Internet
Change of Hard Disk
well,you can install any size you want and make sure you reboot from the cd rom when you reinstall the disc toshiba are hard to reboot sometimes unless you have the reboot disc .. lala linda
Jun 03, 2008 | IBM TP A20M PIII700MHZ 64MB 12GB 14.1"24X...
DFI K6XV3+/66 Motherboard Logo
55 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Steve Frost
Steve Frost
jason
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
