Question about TC Electronic Finalizer EXpress Compressors Limiter Gates
How do i connect my dvd player to my lcd tcl hd tv
  • 567 Answers
Best way is by hdmi cable if you dont have then scart leads
Posted on May 08, 2010
With the correct power will my TV & Surround system work as a streaming device in the Uk. I understand that the network would not be available?
Not sure what you are trying to do. If you use an appropriate power adapter they will turn on but (assuming your equipment is not euro market) Europe uses different signals so they won't pick up any channels. You would have to have a seperate device to tune the channels and convert it to you non euro tv signal requirements. Also if your sound system is your dvd player only discs encoded for the same region as your dvd player will play.
Jul 26, 2016 | TC Electronic Music
My Mackie HD1531 has a high pitched whistling sound, all other speakers work fine with the same power connection and desk connection. It whistles regardless of whether it has a sound input or not.
Sounds like a problem with the horn amp in that cabinet. This is not a user fixable problem and needs to go to the shop. Here is a link to the Mackie support page where you can find a link to the repair shop list.
Mackie Tech Support
Feb 19, 2015 | Mackie HD1531 3-Way 15" HD Powered PA...
How do i connect a dvd player to a sound mixer unit.
Connect the dvd audio outs, normally red and white phono jacks, to the inputs of your mixer. You may need phono to 1/4" phone jack adapters to do this, but they are available at Radio Shack, but hurry as they are going out of business.
Feb 11, 2015 | Music
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
Can a dvd player be installed in the mpc 4000
The unit is designed for a CD unit. While a DVD player MIGHT work as a CD read and burner, it would not likely burn DVD's or read them.
May 28, 2011 | Akai Mpc2500 Music Production Center
I want to connect Gemini Cdm-3610 to my TV can i do that and how?
You can probably patch the audio into the audio input jacks of the TV, however without a video signal there would be no picture on the TV, only audio... It is also possible that without a video signal, the TV may mute the audio inputs...
Dec 12, 2010 | Gemini Sound Products Gemini Cdm-3610 Mp3/...
Korg d3200 screen has lines through it making it very hard to read
This sounds like a failure of the LCD connections at the LCD sandwich. It may require replacement of the LCD screen. If one is careful and is adept at electronics, one can DIY this. Be caareful to keep track of screws and location and be very careful of the cables within the unit. If you are unsure of your capabilities, best to take this to a competent electronics repair shop.
Nov 12, 2010 | Music
My HDMI output on TV keeps flickering on / off when connected via my Yamaha RX2700 amplifier. The signal initially works for about 20 x minutes and then starts flickering. When the HDMI cable is connected...
look for hdmi output in amp if it is rusty or dusty put a drop of cleaning oil in it and insert cable 10 times init and see if it works there is nothing wrong in cable as it works directly must be a connection problem due to dust or rust
Jun 04, 2010 | Music
Mp3
The problem is that a CD has a stereo signal and the Marshall is mono.
You could make a simple mixer cable with resistors as a completed cable is not something you will find easily.
Take three 1K resistors joined at one end and connect the open ends of those one each to the three terminals of a stereo plug that fits you CD player.
Connect a mono plug and cable with "hot" to the joined connection of those resistors. Connect the ground shield of that cable to the barrel connection of the stereo plug that one of the resistros is also connected.
NOTE: if you use the "line" output of the CD player, then use 10K ohm resistors instead of 1K.
May 06, 2010 | Marshall 15 Watt Guitar Amp
TC Electronic Finalizer EXpress Compressors Limiter Gates Logo
432 people viewed this question
Top TC Electronic Music Experts
Michial Gueffroy
bigdawg7299
Tom Chichester
Are you a TC Electronic Music Expert? Answer questions, earn points and help others
