Question about HP Photosmart C5280 InkJet Printer
Why do i get the message insert a memory card?
Why do I get the message "insert a memory card" when I want to print?
  • 100 Answers
Pls remove any memory cards form the printer... then try to print. If there is no memory cards in the printer and still the error messge you will receive, follow the steps :
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
4. Check for the functionality.
Posted on May 08, 2010
Error message: communication error
I use a USB cable and never see a communication error
Jul 08, 2015 | Canon PowerShot SX520 HS Digital Camera...
How do I print from Casio EX-Z500 internal memory?
Try downloading them to the computer first and then print them from there.
Dec 12, 2017 | Casio Exilim EX-Z500 Digital Camera
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Aug 15, 2011 | Lexmark P350 InkJet Photo Printer
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Can't download to computer from memory card
there should be 2 to 4 inserting ports in the printer for memory card, so you have to just insert the memory card in right port and there is also some type of jecks for memory cards to insert them in card readers.
Apr 13, 2009 | Computers & Internet
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Aug 21, 2008 | HP Photosmart C6280 Printer
HP Photosmart C5280 InkJet Printer Logo
180 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
