Question about Akai VS-J200EA VHS VCR
A faulty appliance (refrigerator) caused the power in the whole house to switch off. When power was restored, the VCR (HR-J200EA)would not come back on (no lights seen on front panel). I tried to switch VCR back on but it would not work. What can I do?
    Sergeant:
  • 144 Answers
From the problem i can understand that there may be high supply of power in this case only by calling the technician you can solve the problem. Remember one thing before repairing try to know the cost because for this type of repair it may cost more than the ordinary one.
Posted on May 08, 2010
  • Akai Master
  • 12,061 Answers
Http://www.eserviceinfo.com/downloadsm/28259/Toshiba_M-653.html
above is a generic training manual, this will give you an idea of whats required to service and repair a unit such as this. usually when this happens, it is a Power Supply that has taken, a power spike, surge etc. usually they are cheaply repairable, from you authorised service center, Akai, in your case, ask for a "Quote" before proceeding with any work, that way at least you will get an idea as to weather repair or replace.
Power went out. Is there a way to reset it?
If all the power went out in your whole house, then you need to flip the main breaker switch off then back on again. This should restore power.
If only frig went out, then which secondary breaker switch is "triggered" and flip off then back on.
Dec 31, 2011 | Refrigerators
I insert the tape and it stops and the power shuts off. If i turn the power on, it ejects the tape
This sounds like a problem caused by the Mode Switch. These in VCR's can cause all sorts of odd things. The switch can become faulty, or just get dirt in it. The switch tells the electronics of the VCR which position the mechanical parts are in. If the electronics get conflicting information, then it will power down the VCR. Another cause of a good mode switch to give wrong info, is damage to the mechanism. This throws out the timing.
A spray of Servisol Video 40 on the switch will restore a dirty one. The other causes are more tricky. Since the whole thing will need to be set up again in position. This will most likely require the service manual as most VCR's are never set up in the eject mode! After any faulty parts are replaced of course!!!
Nov 05, 2011 | Toshiba M684 VHS VCR
Hi there, i have a two door westinghouse fridge it's 4 yrs old, we had a storm monday afternoon and came tuesday morning it had a power search then the whole thing just swtch off and also all the major...
Unplug the fridge, plug in a different appliance to the outlet to make sure the outlet isn't bad.If it trips the breaker for that circut might be bad.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Westinghouse Refrigerators
My vcr will accept a tape and begin to function only when there is no other electrical device plugged into the same circut. If anything is plugged in at the same time the vcr ejects the tape and wont try,...
Weird one! The only thing I can think that would cause that is that the other things reduce the load on the socket so the VCR can't get enough power to function right. Have you had an electrician check the wiring in your house and inparticular that socket? Otherwise I would guess it's a power supply problem on the VCR. It's not the fuse anyway they would just blow causing no power at all!
May 12, 2010 | JVC HR-A51 VCR
I NEED TO FIND OUT WHY MY VIDEO TAPE KEEPS EJECTING ITS SELF.
Often this is caused by a faulty mode switch in the VCR. The mode switch tells the microprocessor of the VCR what position the vcr is in, so when it goes wrong the whole system goes wrong!
Apr 19, 2010 | Electronics - Others
I had a power outage. After power was restored
Replace the adaptive defrost control part number 240375803. About $100.00.
It is located in the fresh food section on the top left side behind the plastic panel.
Apr 01, 2009 | Frigidaire FRS26KR4A Side by Side...
JVC VCR HR-J200EA
Hi. I'm after an owners manual for a JVC video recorder HR-J200EA. Email: postiemarg@hotmail.com
Jun 05, 2008 | Akai VS-J200EA VHS VCR
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
DVD-VCR Reorder, Model DVD-V5650
Hi.
On the more modern vcrs this problem can be caused by several things, Faulty mode switch, Deck alignment incorrect, reel idler faulty.
I would advise if the machine is only 3mths old it will be still be under warantee so take it back to shop.
Chris.
Nov 26, 2007 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
