Question about Minolta EP1030/1030F CS/PRO Copier
How can i remove the drum in the unit - Minolta EP1030/1030F CS/PRO Copier
  • Minolta Master
  • 12,061 Answers
Http://www.eserviceinfo.com/downloadsm/20504/Minolta_EP%201030.html
http://www.fixdevice.com/smanuals/file/41998.html
Ok get both of those manuals, the last one is a service and repair manual, it has step by step how to's showing what to do.
Posted on May 08, 2010
    Sergeant:
  • 144 Answers
Yes, you can remove the drum, but it is the most sensible part and be careful.
My suggestion is call your customer care for a better assistance to remove or replace the drum.
Thank you.
Call service 7410:0711657
Open top and front cover and remove Developer Unit. Next, open the left cover (at the waste toner box), remove waste toner box. Unlock the drum unit lock and then remove the drum unit. If the printer is dirty inside, clean it with vaccum cleaner. Be carefull with the drum surface, not to scratch it. Put the Drum Unit into a dark place if you remove the unit for a longer period of time. After you cleaned the printer inside, put the Drum Unit back. Dont forget to push the unit firmly, for good electrical contact. Put all the other components back and turn on the printer.
May 31, 2014 | Kyocera FS-2000D Laser Printer
Tip
Drum needs to be replaced message,Remove waste toner,Waste toner full
Save money by removing your drum units waste toner yourself.By removing waste toner the drum life will be increased.Remove the waste toner every 3 to 5 thousand prints.
The main cause of drum failure in this model is caused by waste toner build up at the back of the drum,this cause the drum cleaning blade to put more pressure on the drum and.
Slide the platte-ned cover Assembly to the left open the left cover,remove the drum and developing Assembly like you do when you have to remove a paper jam.The drum and developer assy is attached by 2 blue clips,unlock the clips and separate the def and drum.On top of the drum unit the is a plastic plug that you can remove and trough out the toner in a dustbin with plastic bag coverd.Do not use this toner again in the machine.
Reinstall the plug and connect the drum and developer unit with the two clips.Reinstall the unit.
By removing the waste toner regally you will save on service cost as well.
on Dec 05, 2009 | Canon ImageRUNNER 1670F Copier
I have the 7410:0043689 error
This error 7410 is a Drum unit non- installing error. The drum unit is not installed or not installed properly.The drum PWB EEPROM does not communicate normal. Detaching and refitting the drum unit;
Procedure
Remove the developer unit Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
5. Open the left side cover and then remove the waste toner box.
6. Unlock the drum unit lock and then remove the drum unit.
7. Check or replace the drum unit and refit all the removed parts.
Good Luck
Jun 04, 2013 | Kyocera FS-4000DN Laser Printer
Error code 7410:0167274 on a Kyocera FS2000D, what does this mean?
The 7410 indicates a drum error (see below) the 0163053 is the number of prints made by the printer. The drum was most likely knocked loose when installing toner.
Drum unit non- installing error -
Detaching and refitting the developer unit Procedure
1. Remove the developer unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
I hope this is helpful,
Shawn
Jun 10, 2011 | Kyocera FS-2000D Laser Printer
Kyocera FS3900DN changed toner and got error 7410:0163053 to call for service
Shawn
Feb 25, 2011 | Kyocera FS-3900DN Laser Printer
Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
Apr 09, 2009 | Panasonic FP-7735 Black and White Copier
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
DO NOT REMOVE THE CANON GP 555 DRUM
It is easy, open the front door and fold down the transport unit & the drum is to the left of the developer aunit. There is one screw that hold the drum in, unscrew it and before you pull the drum unit out remove the grey filter unit to the left of the drum, then remove the drum unit. Note there is a corona wire as the primary charge, it is not a roller. There is a screw that holds the unit in on the rear of the drum unit and also, there is one silver secew that is attached to the cleaning unit for the post corona wire. Some C.Q. problem can be fixed with replacing the post corona wire. Good Luck
Nov 19, 2008 | Canon imageRUNNER 400S Copier
Kyocera 1810 drum replacement
First, what kind of technical background do you have? Also when replacing the drum you should replace the drum blade. Most of the drum/blade kits do not come with padding powder anymore so you will need the padding powder also -- if you do not use the padding powder you will get drum blade jitter and trash the brand new drum!!!!
TO replace the drum you will need to remove the toner cart., 1-2 covers, the dev. unit (developer) and then the drum unit. You will then have to take the drum unit apart to remove the old drum and blade. *****NOTE***** DO NOT TOUCH THE DRUM SURFACE OR THE MYLAR (RUBBER PART) OF THE BLADE WITH YOUR SKIN!!!!!! The oil from your skin will damage the drum and could damage the blade, again -- then they would be trashed.
I would spend the money to have a trainer tech. come out and replace/ rebuild your photo conductive unit for you. It would be money well spent.
Oct 29, 2008 | Kyocera KM-1510 Copier
Remove photoreceptor xerox 1505
1-6-4 Image formation section (1) Detaching and refitting the image formation unit Follow the procedure below to replace or check the image formation unit. Prucedure 1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit. 2. Remove the waste toner tank and toner container. 3. Remove the two screws holding the waste toner tank cover and then the cover. 4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation unit.
(3) Detaching and refitting the drum Follow the procedure below to replace the drum. Cautions: • Avoid direct sunlight or strong light when detaching and fitting the drum. • When removing the drum, spread paper underneath as there is a possibility of toner spill. Toner spill can be reduced by inserting an approximately 20-mm thick pad under the image formation unit toward the developing section and removing the drum with the unit slightly tilted. • Hold the drum at the ends and never touch the drum surface. • After removing the drum, keep it in the drum case or storage bag to protect the surface from light. Prucedure 1. Remove the image formation unit (see page 1-6-27). 2. Remove the main charger unit (see page 1-6- 28). 3. Remove the four screw and blade spring, and then open the cleaning unit. • Slide the cleaning blade back and forth and insert an approximately 4 to 4.5-mm thick spacer between the retainer at the rear of the cleaning unit and the housing.
4. Remove the screw holding the drum grounding plate and then the plate. 5. Remove the E ring from the drum shaft.
6. Remove the screw holding the upper developing seal and then the seal. Figure 7. Pull the drum shaft out and remove the drum. • Detach the drum horizontally. 8. Replace the drum and refit all the removed parts. • When replacing the drum, insert a sheet of paper between the drum and developing roller to prevent damage to the drum. • Check the letter indicating the drum type printed on the new drum flange. • Securely insert the drum shaft as far as it will go. When turning the drum shaft, turn it in the direction indicated by the arrow marked on the image formation unit frame. • Rotate the drum in its rotational direction and check that the cleaning blade does not flip up. 9. After replacing the drum, run maintenance items below. • U109 “Setting the drum type “ (set to the drum type printed on the new drum flange) • U110 “Checking/clearing the drum count”(clear the drum count) • U111 “Checking/clearing the drum drive time” (clear the value)
Oct 27, 2008 | Kyocera KM-1505 Copier
100 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
