Question about InFocus ScreenPlay 4805 Multimedia Projector
Projector turns off after 3 minutes, lamp needs replacement?
Projector turns off after 3 minutes, gives us three blinking red lights. This should indicate the lamp is bad -- but after turning it off for 1 minute (per instructions), the lamp does restrike successfully. We get a picture, but only for another three minutes when we get the same problem. Brightness and image are perfect. It appears the lamp is working properly. We have 2079 hours on the lamp; unit was recently repaired but only the fan was replaced.
  • jennifere13 May 08, 2010
    Sorry should have mentioned -- filters are clean, both on lamp and on unit. What does "resetting" the lamp filters mean, something different from cleaning them?
  • 144 Answers
Try reseting the filters for the lamp and also clean the air/dust filters.
Posted on May 08, 2010
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Sony projector 3LCD lamp/cover blink red
When I plug the LCD the LAMP/COVER flsh blinking red light
May 28, 2012 | Sony Office Equipment & Supplies
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
Infocus X1 Projector started with 3 blinking red lights.
Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
Mar 09, 2010 | InFocus X1 Multimedia Projector
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
Infocus projector won't turn on
From the infocus_lp650 manual
Table 2:
Red LED Behavior Explanation
One (1) blink The lamp won't strike after five (5)
attempts. Check the lamp and lamp door
installations for loose connections.
Two (2) blinks The lamp counter hours have exceeded
lamp life hours. Replace the lamp and
reset the lamp hours counter.
Optional Accessories Part Number
Three (3) blinks The projector has shut down the lamp.
Replace the lamp. Contact Technical Support
for repair if replacing the lamp does
not solve the problem..
Four (4) blinks The fan has failed. Replace the lamp (the
lamp module contains a fan). Contact
Technical Support for repair if replacing
the fan does not solve the problem.
Five (5) blinks The projector is overheating. Check for a
blocked air vent. Contact Technical Support
for repair if clearing the air vents
Jun 18, 2008 | InFocus ScreenPlay 4805 Multimedia...
Won't piwer on
Tried to turn it on? Sounds like you need to replace the lamp. However, I got an additional week out of my unit. Although poorly dimmed and the red Lamp light blinked constantly for that one week, at least it gave me enough warning to seek out a replacement. But so long as you're not mistaking the Power/Standby or Timer light for the Lamp light then I would have to agree with you. http://store.l-f-l.com/prod/A-1606-034-B Includes shipping to the United States and no sales tax outside of California.
Aug 16, 2007 | Sony XL-2100U Projector Lamp for...
InFocus ScreenPlay 4805 Multimedia Projector Logo
781 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
