Question about GPS
My go 510 will not charge the battery. I have renewed the battery but this has made no difference. it will not charge either from usb or mains
    Brigadier General:
  • 4,090 Answers
The the charge circiut is damaged and will need repair. But be warned it is a complete motherboard change and given that 3.5 GPS are obsolete now it will cost more than the GPS is worth.
Please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
While the headset works frequently, it will suddenly stop. Nothing I do will allow it to connect again. I hear nothing through the headset after the initial beep that indicates headset mode was enabled. ...
It sounds like the battery is no longer holding a good charge. There is no replacement battery for this headset. If you are using the original 510 headset you can replace it or pair a different bluetooth headset up to the 500A base. Just keep in mind if you decide on a different style of headset you will not be able to charge it in your base. I have included the link for the 510 replacement headset below.
Plantronics Voyager 510 Replacement Headset
Good luck from Headsets Direct!
Jul 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Toshiba M100 upgraded to Windows 7, i have just renewed the battery but i have a problem with th laptop not charging, info says it is plugged in but not charging, power adaptor is ok. the power charge...
When you say you renewed the battery, does that mean you replaced the battery with a new one? If your system is not charging up, try a different wall outlet. If that does not work, try a new power cord and lastly, a new battery.
After you have ruled out these three pieces of hardware, and you still have the problem, you would want to contact Toshiba for repairs as you are left with a malfunction on the laptop itself. Alternatively, you can contact a local computer repair shop.
Regards,
G33k
May 11, 2011 | Toshiba Satellite M100 Notebook
Usb not charging
The computer will only charge when the camera is switched off.
Try a different computer. It will usually only work from a desktop.
Try a different USB outlet
Try a different USB cable
Dec 12, 2009 | Kodak EasyShare M863 Digital Camera
E machine 510 wont charge!
Yes, remove the battery from the laptop.
Plug-in power adapter and turn ON laptop (without battery).
After the laptop starts up and Windows has settled, put battery back in the laptop.
Allow to charge for a few hours.
Oct 07, 2009 | E-Machines eMachines Desktop PC
Plantronic 510 not charging properly
no it has a smart charge system which does not allow for that to happen.
Thanks,
Nate
Sep 23, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Pavilion zd8000 battery will not charge charging indicator light flashes and the mains light remains constant. Renewed battery, tried another mains adaptor still will not charge. Laptop works whilst...
sounds like the battery may be bad. I would first suggest trying a replacement battery and see if it will charge if so problem solved; if however a replacement battery (that is known to be good) still does not work it is possible that your battery charger on your laptop has gone bad, which is possible but very rare.
Aug 01, 2008 | HP Computers & Internet
Tomtom 510 battery not holding charge
how do i get the battery out of a t/t 510
Apr 16, 2008 | GPS
Bettery replacement for Navman 510
Easy if you're comfortable opening up the receiver and working on electronics. To obtain a 'new' battery you can use Ebay, search for "navman 510 battery" and you should find some for sale. They seem to sell for about $20 including shipping. First find a good environment to work on the receiver, someplace where you can have good lighting and a good place to put parts. You may want to lay down a towel or something so you don't scratch up the receiver and also so if you drop the screws they don't bounce away from you.
First remove the SD card, then the screws from the back. After you have the screws out, slide your finger nail (NOT screwdriver) along the seam pressing inwards, the cases should separate and you should then be looking at the inside of the receiver. First, you'll have to disconnect the antenna connector. Then you'll have to remove some screws holding down the main circuit boards inside. Be careful when removing components that you don't crack the boards, they're very thin! After you have the boards out you'll be able to unplug the battery from the main board (they ran the cables under the boards so you have to remove them to get the battery out). Put the new battery in and reassemble.
Make sure to fully charge the battery before you first use it.
Oct 13, 2007 | Navman ICN510 GPS Receiver
ClickSmart 510 Will Not Be Turned On
make sure the terminals the batterys go into arent dirty, thats usually one of the main reasons a camera wont function. hopefully it works out, good luck
Aug 23, 2007 | Logitech ClickSmart 510 Digital Camera
GPS Logo
48 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
