Question about Maxtor Shared Storage II 2TB Network External Dual-Drive Hard Drive
My Maxtor 2TB hard drive is failing when I operate it, I have a lot of info on it and cannot access it, when I restart it won't show on my computer and after 5 minutes will say I have to format it.
  • 532 Answers
I have a Maxtor as well that behaves badly sometimes. I did some research online and found out that the drives are using a Linux type of OS inside. They get out of sync and cause the drive to think it is not ready.
I found that if I plugged and unplugged the drive until I got a response, I could access the data.
I would recommend a different drive for your stuff. One that doesn't use this type of OS.
Maxtor also has a problem with one of the drivers under Windows 7. All in all, I recommend replacing this drive if you can retrieve the data.
Posted on May 08, 2010
Computer doesn't recognize hard drive
Is the drive greater than 2TB and you are using a 32-bit operating system? If the drive is greater than 2TB, you need a 64-bit operating system to be able to access it as a single drive. Right click on My Computer. If it doesn't say, it is probably a 32-bit operating system.
Mar 31, 2014 | Seagate 3TB Expansion External Desktop USB...
Why won't my hard drive show up after I restart my computer?
I'll Suggest you to open the case and connect the hard driver data cable connector to other port in the mother board. Second thing you can do is change the data cable of hard drive and try with other one.
Third thing you can do is check if your SMPS is providing proper Voltage or not.
Try above steps and let me know the results.
Aug 10, 2012 | Computers & Internet
I-series enclosure won't work properly with maxtor 4D040H2
I have two suggestions.
  • First check and clean your connections.
  • Update your drivers by CLICKING HERE.
  • Lastly, let Microsoft scan your operating system and fix, if necessary, any problems in three easy clicks. CLICK HERE
Apr 29, 2012 | Maxtor Hard Drive
Why my maxtor hard disk showing SMART Failure?The maxtor is my secondary hard disk drive...
Hello
The smart control inside the hard drives is to let you know that a drive is about to fail. If you restart your computer and bring up the BIOS you should be able to shut off the SMART warnings. That wont fix your drive, but at least you wont be bothered ...
I would copy the info off that drive asap and save it. SMART is not always right, but its right most of the time and problems will come.
Best of LUCK
Nov 27, 2010 | Maxtor Hard Drive
Drive Wont format
First, because they came from the Lacie external drive, they were raided to look like a single drive. To format them inside your computer. You have to go into computer management to initialize each drive at a time and format them by right clicking on the drive and format
May 06, 2009 | Maxtor Hard Drive
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from www.thefreecountry.com/security/securedelete.shtml
Jul 21, 2008 | Maxtor Hard Drive
No recognize
The drive will need to be extracted. The enclosure and/or drive has failed and is causing your computer to fail. Remove the drive carefully from the enclosure and test it in a good, known working stable enclosure...
www.drivesavers.com
keep me posted
Oct 29, 2007 | Maxtor OneTouch II 300 GB Hard Drive
LaCie 1 TB Hard drive won't boot
I lave lots and lots of experience with LaCie Drives (I have 6 of the 2TB models). Every, every, every time a drive fails or runs slowly, it is the power supply. I have now replaced 5. They run very hot (so does the drive), and fail pretty often. It looks like the voltage drops just a smidge, and access times seem to increase, i.e., the drive "runs slow". Then it won't boot at all, and the blue light keeps blinking. Fortunately LaCie has replacement power supplies in the store. Buy a couple extra. I am married to the LaCie drives now, or I would probably switch brands. I kind of guess that they know about this because I contacted the help desk, and he wasn't surprised. Maxtor has a nice drive, and the Calvary drive is $150 cheaper. A drive is a drive I guess. By the way, if anyone is listening, how about building a QUIET, COOL drive with and INTERNAL POWER SUPPLY? GOT IT? All the cords and power supply bricks make me crazy. It might be nice to see a stackable drive where the top of one drive mates to the bottom of another, carrying network info as well as power to the drive above. Hint, hint. We all are building systems with ungodly amounts of storage. Too bad the manufacturers aren't building drives with the durability we need.
Oct 08, 2007 | LaCie (301074) 80 GB Hard Drive
Maxtor personal storage 3200 200 GB hard-drive does not show up in my computer
The volume partition may be failing. So your machine can see the drive but you still cannot read or write to it. I would open it and extract the drive, to eliminate whether the drive and / or enclosure is at fault.
Oct 08, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Shared Storage II 2TB Network External Dual-Drive Hard Drive Logo
214 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
