Question about Sanyo Performax SC-U126 Vacuum
My vacuum cleaner is not sucking. It's overheated and stopped
My vacuum cleaner is not sucking. I looked the hose and it is not clogged. I cleared the bag. After running it for some time, it automatically stopped and was not running any more. May be overheated.
  • Anonymous Mar 17, 2014
    my vacuum cleaner was running fine thenjust stopped
  • Anonymous Mar 29, 2014
    Vacuum cleaner stopped working. Suspect overheating. After cooling off it still does not start.
    Sergeant:
  • 144 Answers
In this case it is motor problem, you can sort out only by calling the technician. Call the customer care and check out the cost for repair, if it is very high you can go for a new one and be in peace of mind.
Thank you.
Posted on May 08, 2010
Why miele s8 vacuum does not suck well
Try taking it apart and see if their is an obstruction.
www.mieleusa.com/service/index.asp
Jun 26, 2014 | Miele S8 UniQ S8990 Canister HEPA Vacuum...
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Vacuum goes on for a few seconds then shuts itself off when I go to start again it goes for a few seconds then stops new bag in vacuum can I fix this problem Donna
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Apr 06, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Dirt is being sucked into the cleaner but not reaching the clear bin
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright
Vacuum not working
heatman101
Feb 14, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
The Dirt Devil 085850 doesn't pick up anything!
the intake hose is clogged thats the clear looking hose that comes up from the bottom on the back side.you will need a coat hanger wither the end bent so its rounded.on the back where you sere the clear hose it conects to a fitting that is held in by one or 2 screws take them out and work the coat hanger down through the intake hose.you should be able to push the clog out through the bottom
Dec 04, 2008 | Dirt Devil Featherlight Bagless Upright...
Vacuum cleaner doesn't ****
Hello!!
May i know the model please
Aug 29, 2008 | Vacuums
Bissell 1699 ProHeat Clearview Steam Cleaner won't pick up
Usually if the water isn't being sucked up is either the filter in the lid of the tank is clogged, or the gasket that sits on top of the clear window nozzle and the tank is missing.
Jan 08, 2008 | Bissell 1699 ProHeat Clear View Upright...
Sanyo Performax SC-U126 Vacuum Logo
230 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
