Question about Toshiba e-STUDIO166 Printer
Printer display shows plz check settings & when i hv read the manual i got an answer plz press stop/clear button & key 8 u got a code & tell the code to service representive
    Sergeant:
  • 144 Answers
You got the answer for the solution, call the customer care and tell the error code they will tell the solution in the phone, if not they will send the technician to sort the problem
Thank you.
Posted on May 08, 2010
How to Clear the "Unable to Print" Brother DCP 7055 Printer Display
Reset Methods for Brother Printers
  1. Disconnect Brother Printer from power cord.
  2. Press Set button and while holding the Set button re-connect the printer to the power cord (electric source).
  3. It will display an error message "Machine Error 46? on the LCD
  4. After the Error code appear, press the "arrow up button" ( ^ ) there will be numbers that are going to be display.
  5. Choose 8 then press Set Button
  6. Press Arrow Up button again then choose Zero (0) and press Set Button Again, now you will enter Service Mode.
  7. Press "Mono Key/Button" 25 times or until "Purge Counter Appear"
  8. Now press arrow up (^) again then choose "2" press Set Button
  9. Press Arrow Up (^) again then choose "7" press Set Button
  10. Press Arrow Up (^) again then choose "8" press Set Button
  11. Press Arrow Up (^) again then choose "3" press Set Button
  12. The purge counter will be reset to Zero.
  13. Now Press Stop/Exit Button
  14. The printer will return to "Machine Error 46? again
  15. Press Arrow Up (^) then choose 9 press Set Button
  16. Press Arrow Up (^) again then once more choose 9 press Set Button
  17. The Printer will reset then wait until it power up again.
Mar 06, 2015 | Brother Office Equipment & Supplies
Toshiba estudio 181 when i power on the machine and press cleare & stop key its show error c 44
that is mean that you have a problem with the fussier , first open your machin with press 0+8 then press 400 start entarrabt if that don't help you so If you can check the fussar
Oct 05, 2012 | Office Equipment & Supplies
Mp730 says waste ink near full
To reset waste tank full error in MP730.
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press "Set" and the display shows:
Test Mode [1] - [8]
CF-FH3 :WLD-11-02
4b. Press "8" and the display changes to:
Test Mode [1] - [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 - 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button - for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Aug 03, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Display reports: Problems in inksystem. Error no: 0xc18a0306 What do i do?
error detecting ink volume and will need to be cleared by resetting your printer. here are the two ways to reset it.
Reset to default setting
1. While your printer is on, unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys."Enter Special Key Combo" will be displayed.
3. Press "1", "2" and "3" to display Support.
4 Press ">" right arrow button and release when System Config Menu appear, then click OK
5. Press arrow key to display Hardware Failure Status, click OK.
6. When Hardware Failure Status:Clear appeared, press "OK" to clear.
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".
9. The last part is to turn off the printer and unplug at the back, wait for 30 sec, then plug and turn on the printer, if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print
Don't forget to rate this answer.
Thank you for using Fixya.
May 26, 2011 | HP Photosmart 3210 Printer
Control panel shows "H4"
This is a solution from the Xerox Support website (www.support.xerox.com) Give it a try and hopefully it resolves your problem. Take care & good luck.
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 03, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
MEMORY FULL ON SHARP UX-460
In addition to clearing memory this *will reset unit to factory defaults.
*****all of your programmed settings will be erased.
First power down the fax by unplugging, then power on.
After the power is turned on and "WAIT A MOMENT" is displayed, press & hold the STOP key.....until a normal display message shows.
*The above step allows the memory to be cleared! If this step is skipped clearing memory to factory defaults, (below) may not always work.
Press the "function" key followed by ALL of the following
9 * 8 # 7
wait until "diag mode" is showing.
Then press start button, followed by either * or #
until "memory clear" message is displayed.
then press start. If stressful "memory cleared" is shown.
proceed to re-program your fax machine settings.
Oct 20, 2010 | Office Equipment & Supplies
The waste ink tank is near full
Hi
I found this in a forum you can try it see if it work for you.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Also I found this.
First Clean and Dry the Print Head:
I used a cotton swab dipped in 70% isopropyl alcohol (rubbing alcohol). Do not use too much alcohol.
Then dry the heads, again using dry cotton swab. Be careful not leave any cotton threads on the print heads.
Then I padded dry the spongy Ink Absorbers (one for black ink and the other for color ink) using
Separate cotton swabs for each absorber. Do not displace the absorbers. Or you can replace the ink absorbers at this point if you do not want to pad them dry.
Then Proceed to the Waste Tank Reset procedure below:
2. Press "Copy" Key
3. Press "#" Key
4a. Press “Set” and the display shows:
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
4b. Press “8” and the display changes to:
Test Mode [1] – [8]
Please wait
8: PRINTER TEST
[2]---[8]
8 – 3 : EEPROM Clear
[1] : 2PURGE FLAG
6. Press "0" button – for INK COUNT
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 05, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
Error ##334 show up on display. what is it meant exectly ?
2. Press "Copy" Key
3. Press "#" Key
Test Mode [1] – [8]
CF-FH3 :WLD-11-02
Test Mode [1] – [8]
Please wait
8: PRINTER TEST
[2]---[8]
[1] : 2PURGE FLAG
Replace all the Ink Absorbers.
QA4-1012-000
QA4-1013-000
QA4-1014-000
QA4-1015-000
QA4-1055-000
Reset the counter to zero.
Replace the printhead. QY6-0042-000 (now QY6-0064-000)
Should cost you about $54 if in the US.
This will only work a few times. Eventually, it will fail to reset
and you will have to replace the Printhead. I hope this helps.
Nov 13, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Toshiba e-STUDIO166 Printer Logo
146 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
