Question about Diesel Garden
Key ignition switch wires have come off the back. need to know which coloor goes where countax c38h honda ride on mower Many thanks.
5 Suggested Answers
  • 246 Answers
SOURCE: I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 124 Answers
SOURCE: i need to rewire and ignition switch for a Murray
The switch uses a plug in block so there is no "re-wiring" involved. There is a potential problem if you get the wrong switch. There are several switches with the same terminal patter so it is possible to get a switch which will mount to the new switch but can cause a dead short when you key the switch. Be sure the letters next to each terminal on the switch match on the new switch.
Posted on Sep 14, 2009
  • 496 Answers
SOURCE: I have a 1983 Murray riding mower, I need to know
With the model number, you can obtain a users manual. I viewed their sample and it included the wiring diagram... SWEET!
Here is the link for your manual:
http://www.outdoordistributors.com/Murray/Murraypartslists.html
Hope this helps... Good luck!
Posted on Sep 22, 2009
nova2nv
  • 197 Answers
SOURCE: my riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Posted on Nov 22, 2009
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
C38h
CHECK THE WIRING FROM THE SWITCH TO THE CUTTER CLUTCH IT COULD BE BROKEN OF
Apr 13, 2014 | Garden
Need a wiring diagrame for countax 20 50
Type in owner's manual countax 20 50 on Goggle. Scrool down to
pdf A2050 OP MANUAL
Jan 19, 2013 | Garden
I need a wire diagram for a countax c400h
I am sorry but Fixya has no wiring diagrams for any product.
Mar 13, 2012 | Cars & Trucks
Where can I get a replacement cutting deck for a Countax K14 tractor mower?
Not sure of your geographic location but here is the contact data for Countax:
http://www.countax.co.uk/contact_us.htm Call them using the 0800 number on the linked page.
Parts link:
http://www.greenstripe.net/Parts-diagram/Diagram-405_Page-1.aspx
60 32726700 36 IBS DECK SHELL £300.11 view 60 32726601 38 IBS DECK SHELL £301.75 view 60 32726500 32766500_34 £302.82 view 60 32732500 48 DECK SHELL £265.49 view
If you not in the UK, I need to know your location please to locate other sources in your area.
Thanks for choosing FixYa,
Kelly
Aug 24, 2011 | Garden
I need an owners manual for a murray riding mower.
i have a central park murry riding mower, will not turn over with key on,but if i jump selonid it will turn over.
Apr 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My dog tore out some wires on lt1000 17.5 hp ridng mower. inow have it wired so it will start and run,but have one wire i dont know where it goes. from the ignition switch the blue is hot the black im not...
If you unplug your harness from the key switch on the back of the key switch you will see by the terminals letters stamped a S for solenoid a L for lights B for battery G ground and a M for magneto. This will tell you were the loose wires should go. Hope this helped.
Mar 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to wire a ignition on a 65massey fergison
From the key switch you need to run a power wire to the coil positive post.Then the coil negative post goes to point in the distributer.If you don't have an ignition post on the switcn the it gets it's power from the oil pressure switch that will power up the coil as sone as you have oil pressure.Let me know if you need more help.
Nov 26, 2009 | Garden
I have a 1983 Murray riding mower, I need to know the ignition wiring diagram. There's a yellow ignition switch and I don't know where it goes to. There's also a single wire that comes out from the front...
Sep 22, 2009 | Garden
Hello ianh_2007:
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
Garden Logo
56 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
