Question about Keyspan URM-15A Remote Control
Drivers needed for URM-15A / windows 7 64 bit
Drivers needed for URM-15A / windows 7 home 64 bit. i am unable to install using the CD. How can i use it for windows 7 home prem 64 bit.
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
Unable to connect sony hx30v camera with home wifi
The drivers being use may be 32 Bit when 64Bit drivers are required or vis/versa. You need to go with Win 10 version that has all new drivers and security. Review all methods used to connect the wireless devices. Check the device drivers and make certain the updates are there and installed. Check connections, cables etc.
Feb 09, 2018 | Sony Cyber-shot DSC-HX30V 18.2 MP 20x...
I have installed windows 7 home premium 64 bit in my hp probook 4410s laptop, but i am unable to install the audio drivers.What should i do?
some time windows home edition operating system will not support proper driver so u must find the proper driver of windows home. other wise u can re install windows ultimate it will be ok..
Sep 15, 2011 | Computers & Internet
Unable to install hp officejet 4355 in windows
To download from internet you need High Speed Internet connection:
If you are using 32 bit OS use the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-2&lc=en&dlc=en&cc=uk&lang=en&os=2093&product=1138373
If you are using 64 bit OS use the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47767-2&lc=en&dlc=en&cc=uk&lang=en&os=2100&product=1138373
If your internet is slow, please download it to a different computer which has much faster internet connection (may be you can use a library or public internet center), copy the downloaded file in a pen drive or any other memory device, save it into your computer and install it.
:) Dr Tony
Apr 23, 2010 | HP Officejet 4355 All-In-One InkJet...
Use to be able to scan a document and save as a PDF, got new computer with windows 7 now I'm unable to save as PDF
you need to use the driver for win 7. If you have already installed the software using the installation cd, you need to uninstall it first before using the win 7 driver by going to start menu > programs > lexmark 5600 series > tools> uninstall. Then reboot pc. Check the version of your operating system. Right-click on My Computer and choose properties to see if you have a 64-bit or 32-bit OS. Download the proper driver package by going to this link: http://bit.ly/cclHPL . download cj5600Win7en64.exe is for 64-bit OS. or download cj5600Win7en32.exe for 32-bit OS. install the sw and try scanning again. Hope this helps.
Mar 08, 2010 | Lexmark X5650 All-in-One InkJet Printer
Can't install CD for wireless keyboard. Need
Hello!
Usually when I install drivers for hardware I never use the CD that ships with the product. By the time the product has shipped, CD's that contain software for the product are usually outdated since hardware manufacturers are constantly updating software around the time of release and for awhile afterwords. Because of this, I like to go straight to the manufacturer website and download the absolute latest software/drivers for the hardware in question.
Here's a link below to both the 32-bit and 64-bit versions of the Windows Vista software for SetPoint. Depending on what version of Windows Vista you're running [32 or 64], choose the appropriate one and try installing that. If that doesn't work, visit Logitech's Support Website, choose your product, and download the appropriate drivers.
Logitech SetPoint 32-bit
Logitech SetPoint 64-bit
Oct 17, 2009 | Microsoft Windows Vista Home Premium with...
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Reformating my laptop sony vaio
You have to put the windows disk in, and then shut down computer. Make sure the laptop is set to boot from cd. Then follow the on screen instructions.
PS BACK UP ALL YOUR IMPORTANT FILES BEFORE INSTALLING / REFORMATTING WINDOWS!
HOPE THIS HELPS
May 30, 2008 | Computers & Internet
Need drivers for Olympus VN-960pc; os Windows XP home
Vista compatible software can be downloaded here:
http://downloads.olympus-europa.com/consumer/VoiceRecorder/720/eng_2000_xp.zip
After installing the software you need to install following updates
http://www.olympusamerica.com/files/DWPUP4EN.zip
http://www.olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
The software will work with the 32 bit edition of win Vista, not with the 64 bit edition.
Mar 17, 2008 | Olympus VN-960PC
Driver for nec versa fm340
connect the internet
open google search engine
and search the driver by writing
" download driver (nec versa fm340)
Mar 03, 2008 | Microsoft Windows XP Professional With...
Keyspan URM-15A Remote Control Logo
185 people viewed this question
Top Keyspan Televison & Video Experts
Are you a Keyspan Televison and Video Expert? Answer questions, earn points and help others
