Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
I dont have color toners i have only black toner and i get yerror out of toner y and M.I can't print black and white also why ?
  • 4,041 Answers
Hi there
Your printer see,s that the other inks are emty so it will not print this is how they are made, this is why if you print with just black then you can buy the laser printers cheap a mono printer.
Take care Pineworks
Posted on May 08, 2010
What is the amount of magnetic Powder to be developed in the Fuser Section?
None. It is electrostatic attraction.
It varies from each type of laser printer.
Most printers will specify a total number of pages printed from a laser toner cartridge rather than give an actual amount of toner per page. Which I feel would be more likely to be an average value.
Due to the amount of toner being used per page varying on the number of actual pixels that are required - a black dot or a color dot. If a colour dot is required Three toner colors may be involved to get the color required. Where there is a white dot no toner is required.
It really depends on what image is being rendered onto the paper on each different page image print onto the paper.
Color photos use more toner as more of the page is color than when using black and white !
Jul 02, 2015 | Office Equipment & Supplies
I can't print in black and white though I have black toner
Hi, when the printer finished warming up. it will prompt Toner Empty - Stop, use the arrow key changed to continue and you can start printing. remember you must always do that whenever this msg appears.
Oct 09, 2013 | Samsung CLX-3175FN Color Laser All-in-One...
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
My Ricoh SP 232sf wont print at all because the K toner is out of toner but it has plenty of color. Can I force it to print somehow?
Unfortunately, no, the printer won't print even in color if the black toner is empty. The black drum rotates whether the copier is printing in black & white or color, so if black is empty you can't print at all.
Feb 23, 2011 | Ricoh Aficio SPC232SF All-In-One Laser...
When i print toner status black color is faded as well as yellow and cyan, magenta showing white color, can you please give the best solution for this. by the way i am using hp 2600n. thank you very much.
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer.
Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600n Printer.
GoodLuck!
Dont forget to appreciate the solutions if I could have been of any help!
CreativeTECH
Dec 08, 2010 | HP Color LaserJet 2600n Printer
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
My clx-3175 wont print black and white when color toner is empty???
All of the manufacturers do the same thing to get people to buy their toners, if any toner is empty you don't get to print even black. Sometimes empty toner can scratch a drum so that's the excuse they use for making them that way.
Feb 05, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
Printing black/white when color toners are low
Try taking the color toner containers out of the printer and shaking them a bit. Put them back on and try again. This could confuse the sensors into believing that you still have some toner left.
Good luck
Dec 13, 2008 | Konica Minolta magicolor 2300DL Laser...
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
347 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
