Question about Refrigerators
We have an Amana Side by side purchased in 2000. went on a 2month vacation, and turned the freezer temp down, and when we got home turned it back up, and now it won't keep the Ice Cream frooze, everything else seems ok?
    Novelist:
  • 184 Answers
IS THERE A FROST BUILDUP ON THE BACK WALL OF THE
FREEZER INTERIOR? IF SO, AMANA IS MADE BY MAYTAG
AND THE ELECTRONIC BOARD THAT CONTROLS THE DEFROST IS MOST LIKELY SUSPECT. IT IS LOCATED IN THE UPPER RIGHT CORNER OF THE CONTROL PANEL IN THE REFRIGERATOR SECTION {INSIDE BACK RIGHT CORNER).
THE ENTIRE UPPER PANEL HAS TO BE REMOVED TO GAIN ACCESS. WHERE THE WIRES CONNECT, THERE ARE 2
TERMINALS MARKED TEST. SHORTING THESE TWO TERMINALS WILL ACTIVATE THE DEFROST MODE OF THE CONTROL. IF IT FAILS, REPLACE THE CONTROL.
Posted on Mar 27, 2008
Went back from vacation and noticed the refrigerator temp was 72 and not cooling
CK your inverter on top of unit . There's a tech sheet to help guide you in the right direction
Aug 24, 2014 | Viking VCSB423 Side by Side Refrigerator
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
1996 amana side by side freezer somtimes doesn't maintain temp
hello it sounds like the element is faulty, as long as the fan is working, the element switches on when defrost thermostat sensor that the coil is icy up, but if you are not familiar on how to use a multimeter it is hard to know for sure, if you do know how to use a a meter , when the coil ices up and the fan is working check to see if there is power to the element, if there is power the element is faulty, if there is no power then you have a problem with the thermostat
Jul 23, 2010 | Amana SXD524VW Side by Side Refrigerator
Went of vacation and just returned to a puddle of
your ptc relay and contactor on the compressor body is defective,unplug the unit,remove the spring wire or clip that holds it onto the compressor and install a new one,also if it has a run capacitor replace this also
Mar 18, 2010 | Freezers
Amana Model SZD25NL is not cooling at all, neither
compresor fan working? if it is not you need to consider the compressor starter need to be replace
Dec 29, 2009 | Refrigerators
I recently purchased a home. The kitchen has a
Firstly, the thermostats are usually calibrated at one elevation and where the fridge ends up may be above or below that so the number settings on the dial aren't that relevant. You should adjust the thermostat in increments then check the temperature after 24 hours, then adjust again if necessary. The fridge should be as close to 40 degrees F. as possible and the freezer about 26 degrees F. (if memory serves me). The heat you detected is the unit in defrost cycle and should be considered normal if intermittent and a problem if constant. There should be a switch to turn off and on the defrost feature if you determine it's a problem.
I hope this helps you and good luck.
Sep 03, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
FREEZER WORKS BUT FRIDGE IS 50-55 DRGREES
if all that is ok then you need to check the heater and bi-metal / if it starts frosting up you loose air into the refrig side and the freezer will start going down too / frig side gets tem from freezer ,,,,, i bet you have a bad defrost heater / larry
Nov 29, 2008 | Amana ARSE664BS Side by Side Refrigerator
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
