Question about Garden
Can i purchase a metal cutting blade for my sovereign petrol grass trimmer 6102
    Scholar:
  • 110 Answers
Universal kits are available that will allow you to attach a brush cutter blade to just about anything that usually has a line head. The kit contains a selection of bolts, adapters, packing washers etc - you simply select the parts you need to attach the blade. The blade itself is not machine specific.
Posted on May 08, 2010
Hi, I have a Stihl FS88 trimmer with an auto cut 'bump' head. What diameter line should I use please.
Dave, I use the orange 2.4 mm .095" line, seems to give the best results. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-FS-88-108-Owners-Instruction-Manual.pdf
How to Rewind Your Trimmer Head or Sharpen Metal Blades
HOW TO Stihl String Trimmer Head Replacement
May 22, 2016 | Stihl Garden
Do the graphics on the blade face up to the mower or down to the grass when fitting a new blade?
Many blade has grass side stamped into the metal.
You want the cutting to be on the leading edge either way; otherwords, the cutting sharp edge leading. Most blades also turn clockwise when viewed from the top and counter clockwise when viewed from the grass side
Apr 06, 2015 | Garden
Hi, i have a BSA ECCO16 petrol lawnmower, and I have been looking for a replacement blade for a few months, the blade I have at the moment is a power devil 16'' blade with tails, it is cutting
talk with a mower shop
from your description you have a solid bar attached to the hub on the crankshaft with a cutter blade at either end
the cutter blades should have the rear section turned up to create an air flow to throw the gras out the back
you can replac the single blade with a disc that has 4 blades each turned up at the back and that makes cutting easier and a higher rate of discharge out the abck
May 12, 2017 | Garden
4 hp craftsman edger/trimmer. Not getting a clean cut anymore on my grass.
Does this one have a metal blade? If so the blade is removeable for replacement or for sharpening.
Aug 06, 2011 | Craftsman Garden
The line trimmer does not cut the line i have to keep a pair of scissors to trim the string in my pocket
The trimmer guard should have a small steel blade where the line strikes the shield that keeps the line cut to the correct length. Check your shield to make sure the blade hasn't come loose. If it has, you should be able to get a replacement blade for it. If the shield has been beaten up too much, you'll have to replace the shield.
Oct 20, 2010 | Black & Decker 14" Grass Hog Xp...
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Oct 12, 2010 | Black & Decker 14" Grass Hog Xp...
I have a makita backpack petrol strimmer fitted with a line head can i fit a brushcutter blade instead i donot have the full model No it is a 41cc engine it is an early model
Hi Doug,
There are adapters for just about every combination of trimmer, brush cutter blade, grass gator, etc. you can think of.
One of the most handy purchases has been a non specific arbor adapter set. Not only does it have 2or 3 each of the most common nuts in both left and right hand thread, it has inserts that keep every blade, flail and brushcutter I've tried dead center.
It even came with a diamond shaped one for a skillsaw blade that I tried with my Ryobi 4 cycle. That thing turns thorny blackberry vines to powder.
So the answer is yes.
Best regards
Aug 14, 2010 | Garden
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Garden Logo
163 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
