Question about Casio FX-115ES Scientific Calculator
How much will be height from one point to other for 14.4 mts with
Calculating roof height from one end to other for 14.4 meters length with 3 degrees pitch
  • gilljasdip May 09, 2010
    Very helpful. That is right answer
  • Casio Master
  • 7,993 Answers
I am not exactly sure what the 14.4 m distance represents: The horizontal part or the inclined one.
A. If the 14.4m is the length of the horizontal leg, then the height is given by tan(3 deg)=h/14.4m or h=14.4m*tan(3 deg) =0.75467 m.
B. However if 14.4 m is the length of the inclined part (the hypotenuse) of the triangle, then the height is given by
sin(3 deg)= h/14.4m or h=14.4 m *sin(3 deg)= 0.75363 m
As you can see, the values are approximately equal, because for angles less than 10 deg, the sine and tangent are approximately equal.
I am no construction engineer, but it seems to me that a 3 deg pitch in not much of an inclination. Maybe you meant 30 degree pitch.
If that be the case, the calculations are performed the same way as above: Just substitute 30 deg for 3 deg.
Posted on May 08, 2010
What is the length of a hypotonuse triangle with legs being 4 and 3
a^2 + b^2 = c^2
a squared + b squared = c squared, where c is the length of the hypotenuse, and a and b are the lengths of the other two sides in a right-angled triangle.
https://www.youtube.com/watch?v=CAkMUdeB06o
Mar 10, 2017 | Homework
How do you calculate cubic feet?
You calculate a volume. If all the lengths, radii, heights are in feet the resulting volume is in cubic feet.
Example: Right rectangular prism with L=5 ft, W= 3 ft, height =1.5 ft
Volume =(5 ft)*(3 ft)*(1.5 ft)= (5*3*1.5) (ft*ft*ft)=22.5 ft^3
Nov 19, 2013 | Office Equipment & Supplies
What is the area of the triangle with vertices (0,0),(-3,5),(2,-7)
Since you have the coordinates of the three vertices, the most straightforward method is to calculate the length of the sides using the distance formula
d(P_1,P_2)=SQRT((X_1-X_2)^2+(Y_1-Y_2)^2)
where SQRT is the square root function, X_1, Y_1) are the coordinates of point P_1, etc.
With the three lengths available, use Heron's (sometimes called Hero's) to find the area.
Here is Heron's formula.
Let's call the lengths a, b, and c
Let p be the semi-perimeter p= (a+b+c)/2
Then
Area= SQRT [ p(p-a)(p-b)(p-c) ]
Make sure that there is a matching ) parenthesis to the one in the SQRT.
Alternatively,
You can choose the base as the side opposite the vertex (0,0)
Calculate the equation of the line that supports the base.
Calculate the equation of the line issuing from (0,0) and perpendicular t the base.
Calculate the coordinates of the intersection point , call it H, of the base and its perpendicular line (coming from (0,0)).
Calculate the distance OH, that is the height relative to the chosen base.
Use the formula Area= base*height/2
Now it is up to you to choose one of the two methods and calculate the area of that triangle. The second method involves more calculations than the first, and more possibilities of errors. Good Luck
Nov 06, 2013 | The Learning Company Achieve! Math &...
The volume of a rectangular prism is 2,058 cubic cm. The length of the prism is 3 times the width. The height is twice the width. Find the length of the prism
Right Rectangular prism, Length L, width W, Height H
Volume=2058 cm^3=L*W*H
However
L=3W, and H=2W
(3W)*W*(2W)=6 W^3=2058
W^3=(2058/6)=343
W=Cube root of 343=(343)^(1/3)=7 cm
L=3*7=21 cm
H=2*7=14 cm
Oct 29, 2013 | Computers & Internet
My house roof has an area of 120 sq meter and slope degree of 30' how many linear meter my roof has?
the area of your roof is equal to the base (B) times the hight (H) divided by 2.
A = ( B x H )/ 2 = 120
To get the Perimeter of your roof you need to sum the base plus the sides (S)
So P = B + 2 x S
if you have a slope degree of 30 then
B/2 = cos (30) x S
so P = B + 2 x B / 2 / cos(30)
P = B ( 1 + cos (30) )
we also know that
H = tg (30) x B/2
from this last one we can go back to the Area and get a value for B
120 = ( tg (30) x B / 2 x B) / 2
480 x SQRT(3) = B^2
B = SQRT(480/tg(30))
So:
P = SQRT(480/tg(30)) x ( 1 + cos (30))
tg (30) = 1 / SQRT(3) cos (30) = SQRT(3)/2
P = 2 SQRT(30 x (12 + 7 x SQRT(3) ) ) or aproximately 53.8m
Mar 03, 2011 | Texas Instruments TI-83 Plus Calculator
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
How to convert cbm into sq meter
Now cubic meter calculator can be defined as a simple device which is used to convert a given value in meters to it's corresponding cubic meter form. Other than this we can always add the formulaes of the structures to get the volume of the structure by simply entering it's side length or height etc..
Let us consider simple examples :
Suppose that we have to convert 5 meters to its cube. The only thing we would do is that we would enter this value of 5 in the calculator and calculator with do the calculation as mimetex.cgi?%5cdisplaystyle%7b%7b5%7d%7d%5e%7b%7b3%7d%7d and will show the result to you as 125 mimetex.cgi?%5cdisplaystyle%7b%7bm%7d%7d%5e%7b%7b3%7d%7d .
Now if we have added formulaes to this calculator , like for calculating the volume of cube,cylinder and cone (say). Then we can use this calculator in three different cases.
Visit anthony's tuition class. Specialist in H2 Physics Tuition and H2 Maths Tuition.
Feb 10, 2011 | Office Equipment & Supplies
Casio FX-115ES Scientific Calculator Logo
114 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
