You may trying pulling the battery out while its unplugged. Another issue may be the socket where the AC adapter plugs into the laptop. Is it loose, broken prong inside the socket. It should have been able to power up at least for a brief moment just on the battery. Hope this helps ya.
they are quite often around the top row of keys and are usually marked with Nulock and Scroll lock and you may have to press the Fn key with the approiate key you could check out your user manual that should tell you deffitanely where they are
Found a solution for your problem here, search for the words "Satellite A100 & Tecra A7" and follow the instructions the strip cover is a large strip above the keyboard and K/B is "keyboard" find the strip "sweet spots" and use a screwdriver to force the strip out, you'll find the keyboard bolts.
Don't hesitate to come back and reply if the method did not work.
I would contact toshiba.com and speak to their technical department as I am sure I have read a bullitin about that issue by way of an updated driver and BIOS firmware update. Hope that helps.
It sounds like you havent installed the graphic drivers for video card. When you installed xp did you formatt the hard drive and do a clean install? Drivers for the graphics and chipset can be found on the makers website.
