Question about ION Audio iTTUSB Turntable
The belt is slipping from time to time.
When playing LPs, the belt slips from time to time causing a distorted sound.
  • 515 Answers
Time to change the belt.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Serpentine belt
sounds like belt tensioner might be worn out.check to see if belt has tension after u install
Sep 29, 2013 | 1998 Ford Escort
Timing belt slipped 2005 Kia Optima
I would change the belt and do a compression check before starting the engine. That will show any distorted valves.
Jan 20, 2013 | 2005 Kia Optima
I just recently bought a new turntable, and when it plays my LPs, the LPs sound somewhat slower than the original. Does the slowness have to do with the belt of the turntable? Is there anyway I can fi
If the 45's play OK then your belt might not be fitted in the right place. If they are both slow, then either the belt is slack or the drive is faulty.
Dec 09, 2012 | Audio Players & Recorders
VINYL PLAYER SLOWS WHEN I STACK A COUPLE OF LPS sounds funny play fine with just 1
The labels on the LP's stick up higher than the vinyl. These slip on each other when you stack LPs.
One LP sits directly on the turntable mat and has enough friction to turn.
The only solution I can think of is to put something 'tacky' on the labels but this might be detrimental to the label.
Dec 16, 2010 | Audio Players & Recorders
Record player turntable belt is slipping causing distorted sound
A new one might fix the problem, as they do tend to wear out, without breaking. Measure the diameter to get the size right, note also how it fits too.
Feb 23, 2010 | Audio Players & Recorders
My battery light comes on and steering wheel locks up. What could this be?
Steering wheel locks up? or does it get very hard to steer? If it gets very hard to steer sounds like your Serpentine belt is slipping. You may have a bad belt tensioner or possibly somthing leaking on belt causing it to slip. The belt runs the alternator and powersteering. Also check condition of the belt itself. Shiny or streached belt could cause it to slip also.
Sep 26, 2009 | 2005 Chrysler Town & Country
Serpentine belt wont stop slipping
sounds like your belt tensioner pulley may be defective, also check all the pulleys for excessive play in the pulley bearings, these are the most common causes.
Feb 05, 2009 | 1994 Jeep Cherokee
The door open by itself
This can be caused by the drive not closing properly. Usually caused by a slipping drive belt or a faulty micro switch.
If it is a slipping drive belt then the draw closes but the laser assembly does not get lifted into place. If the belt is slipping either replace it or try belt anti slip spray.
If the micro switch has failed then the draw closes but the micro switch doesn't tell the CPU that it has closed so it times out and opens again thinking it has failed to load the disk. If the micro switch has failed it either needs cleaning or replacing.
Alternatively you could just replace the whole draw mechanism however this is normally much more expensive. There are other possibilities such as a faulty micro controller causing this but the two above are by far the most likely.
Regards, Andrew
Regards,
Andrew
Sep 15, 2008 | Audio Players & Recorders
1996 buick regal custom's belt keeps shredding
The first thing i would do is try playing with the belt tensioner. it sounds like the belt is lose and when the engine warms up the belt starts to expand and slips off.
Aug 14, 2008 | 1996 Buick Regal Olympic Gold
ION Audio iTTUSB Turntable Logo
148 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
