Question about Sony (CDU5212) Internal 52x CD-ROM Drive
Upgrading !!!!!!! i have this cd rom drive and i would like to know how to find out what DVD burners i can upgrade to my mother board is an intel cayman ca810 .
    Sergeant:
    Champion:
  • 236 Answers
Any of the as long, just do your reasearch man
Posted on May 08, 2010
How do I update my ide driver for my cd rom?
IDE has been out of date for many years, you're likely having issues with OS or your motherboard just as much as anything.
Explore the option of a cheap upgrade. Intel i3 with onboard graphics, any LGA1150 socket motherboard, 4-8GB of DDR3 RAM and a 400W power supply (only need more wattage if you're running dedicated graphics). All HDDs and optical drives will be SATA on new boards, which is the standard that replaced IDE. You should be able to build a decent, lasting system for under 500 bucks USD - and something that will outperform any PC using IDE.
Aug 30, 2014 | Computers & Internet
How can I fix a non-working CD DVD ROM Drive. The
it depends on the original fault. can be the laser or the bus board
Oct 05, 2013 | LG GH22NS50 22X DVDRW SATA Drive OEM...
How do i instal as a second player on an intel board
you remove the first dvd or cd rom. in the back where you plug in the cables, search for a diagram of master, slave and cable select pin sets. on both of these roms, there will be one. set one to master and the other to slave. make sure the master is connected to the ide cable plug closest to the motherboard. the slave will be the last one on the IDE cable.
Jun 04, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
After installing windows 7, the LG DVD drive doesn't work and windows says it cant install the driver
Many older ICH7 chipset drivers as well as generic derivers has been removed from the winodws Latest Built, for you it it seems the cd/dvd rom drivers are missing.
I here give the link uploaded by me, which contains the driver for CD/DVD ROM fro windows 7, Please open device manager and manually locate the CD/DVD rom and select the .inf file to install the driver
http://rapidshare.com/files/297330669/CD_ROM_Drive.rar.html
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Rename CD-ROM Drive.txt to CD-ROM Drive.rar!
@ADDeveloper
Try the Intel package(link posted before), that's an Intel mobo.
Oct 24, 2009 | Computers & Internet
Vista ultimate does not pick up dvd rom
how did you use it? where you using your dvd rom when you were still in vista basic then upgraded it to vista ultimate? if so, probably you havent installed the drivers for your dvd rom after upgrading to ultimate.
Feb 06, 2009 | Sony Optiarc AD-7170S Burner
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Sound card not working ( no sound output ) mother board intel 810E
Go to Settings, Control Panel, Sound and Audio Devices, check "Place volume icon in the taskbar." In your Device Manager, pls verify that the drivers for your sound card are completely and correctly installed with no yellow or red markings. Likewise, verify that in your CMOS/BIOS settings, the onboard audio has been enabled. The sound driver/installer for an Intel CA810E has the filename 4035full.exe and uses a DOS component.
Should this not work, you might not have an Intel motherboard but one that just uses the Intel 810E chipset. Please post back with a more specific motherboard brand and model.
While it is true that the 810E chipset is by Intel, it does not necessarily mean that the motherboard entirely is by Intel. It could be by Asus, MSI, PCChips, ECS, Soltek or others. The sound therefore need not be the same for all versions of motherboards using the said chipset.
The Intel mb that uses this chipset carries the model CA810E or CA810 which uses Creative Sound Blaster* AudioPCI 128V audio solution or Crystal Semiconductor CS4297 AC '97 stereo audio codec;
The Asus CUWE-FX/RM, FlexATX or i810E uses the same Intel 810E chipset but different sound. Asus can and may use CMI, Crystal, Creative, ESS.
An ECS BKi810E(V7.3) uses the same Intel chipset but C-Media 8738 for sound.
An MSI MS-6188 uses the same chipset. It may have used an Avance-Realtek AC97 for sound.
Hope this be of some help/idea. Pls post back to confirm that you have an Intel CA810 version or by some other motherboard manufacturer.
Good luck and kind regards.
Nov 06, 2007 | Aardvark Direct Pro 24/96 Sound Card
Help
My only sulutionis to buy a external sound card that has 2 sound ports on cd in aux in place the cd+rw on the cd aux in and have the dvd burner on cd in disable on board sound for the external sound card to have the IRQ setting of the on board sound card the best soundcard to go for is soundblaster live or any one in this range as you are going to play dvds on pc the best program for this is Powerdvd from Cyberlink
Aug 13, 2007 | Lite On LTR 52246S CD-RW Burner
Firmware upgrade failed
Have you tried the following - right click my computer>properties>hardware>device manager>right click on your burner drive>properties>driver>roll back driver Hope it works out, let us know ;]
May 27, 2006 | LG GCE 8525B CD-RW Burner
Sony (CDU5212) Internal 52x CD-ROM Drive Logo
55 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
