Question about Toshiba e-Studio 205 Copier
E-studio 2500c "network host is busy"
I'm trying to print a (normal) page from my MacBook (10.5.2) across our Novell network to the Toshiba e-studio 2500c. But it keeps telling me "Network Host xxx.xxx.xx.xx is busy. Will retry in X seconds..."
But it never stops being busy. My colleagues with PC:s print away without a problem.
Any idea of what might be behind this?
Thanks!
erik
  • 43 Answers
You can try to print directly to the machine (not going through the novel system) using either apple talk or ip printing
Posted on Jun 01, 2008
Why I get lines on my photos jpeg
If lines appear when scanning/copying from document feeder only, you need to clean the narrow scan glass located to the left of the main glass. If lines are present when printing, could be a drum/developer problem.
Oct 06, 2014 | Toshiba E-studio 2500c Color Copier...
I have a toshiba 2500c, that is printing with a red line down the centre of the page. It only started to do this now, we have had the printer for ages never a problem. Any one know why?
maybe your having problem with your magenta drum unit maybe there is a dirt on the developer unit ,otherwise clean the slit glass of the imaging unit with the cleaner brush located in the front back cover of your machine..
Feb 21, 2013 | Toshiba e-Studio 350 Copier
Print enevolopes
You are correct. There are no settings listed for envelopes at the Toshiba Interactive Tutorial.
Mar 29, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 2500c Fax board
No need, just the fax board in order to do faxing. But if u have printer kit, u can do network fax.
Aug 25, 2009 | Toshiba E-Studio 3511 Color Copier
Problem with Toshiba e-studio 280- need vista 64 bit driver
You update your copier driver for 64 bit windows suppoted.www.toshiba studio 161.com
Mar 11, 2009 | Toshiba e-Studio 161 Copier Copier
C448 on Toshiba e-studio 2500c
C448 indicates Heater lamp lights continuously for a certain period of time when the pressure roller temperature during ready status is higher than the specified.
1. Clear status counter
Enter 08--> 400 --> change the value from "32" to "0", press Enter and restart MFP.
If occur again, u need to check followings:
1. Check the power supply and fuser unit
2. Check the LGC board
Feb 04, 2009 | Toshiba E-Studio 161 Copier
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Toshiba e-Studio 205 Copier Logo
436 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Electro Med Services...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
