Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
My PSP cannot surf to internet
1.It has a correct details to find the access point
2.The WLAN switch is turned on
    Problem Solver:
  • 14 Answers
Try to restore your default settings of our psp...its the easies way to fix that..
Posted on May 08, 2010
  • Lord Matsuki
    Lord Matsuki May 08, 2010
    restore your settings to default on the psp i that should do it
How to internet? realy i dont know
Hi jerichoville,
First off, you have to be in an internet hotspot and your PsP WLAN switch should be turned on ( slide the switch at the left side of the psp upwards). A hotspot means that the area has internet signals that your wireless device can pick-up. If you are at home, make sure that your wireless router is functional.
Now, the steps : -Go to the Main Menu of your PSP. -Go to Settings.
-Scroll down to Network Settings (press the X button)
-Select Infrastructure Mode.
-Select New Connection and assign a name to the connection, then go to the next menu by pushing the Right Directional Key
-Select the Scan, you should now an access point
-Select an access point ( if you see multiple access points, select the strongest network with the Security setting of "None") -Confirm your security setting from the different choices. "DEFAULT" is just about always the correct choice. Push the ">" button again and again until you reach "DEFAULT" -Skip past the Address Settings by clicking the right directional button ">". You should now see a confirmation screen, just click ">". - Press X to save your sttings - Go to TEST CONNECTION and then press X (You should now be connected to the internet at this point.) - Press HOME but this time use the ">" button to move all the way to the right, then "V" to go down to INTERNET BROWSER There you go. Enjoy surfing. Wishing for you to get the best results. All the best to you.
Jul 24, 2011 | Sony PlayStation Portable (PSP) Console
My psp 3004 internet connection not supported what would i do
Hi yashb22,
Connecting to the internet using your psp is almost the same as connecting through your laptop. If you're having connectivity issue please try to check the error. One of the common error is WLAN switch is off, so make sure that it's properly toggled to the right. If you've already checked and still can't connect try doing the following steps below:
1. Make sure to turn on your PSP as well as the wireless/WLAN switch.
2. Then Navigate to " Network Setting".
3. Select "Infrastructure Mode".
4. Now Select "New Connection" and Name this connection.
5. Navigate to "WLAN Settings" Select "Scan".
6. Your router should now be listed.
7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None".
8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA.
9. Then navigate to "Address Settings". Select "Easy".
10. Go to "Setting List". Verify that your settings are correct.
11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X.
12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection.
Hope this information will be helpful.
Thank you for using FixYa.
Jan 16, 2011 | Sony PlayStation Portable (PSP) Slim...
I have a new psp 3000. I can't get internet access. It finds the SSID, good reception=75%. WLAN on, but its saying "a connection error occurred. Connection point could not be established. Check...
Hi stagedoorste,
You may notice that sometimes connecting your PSP to your network seems like a hard thing to do. But if you're aware of the basic configuration you can say that it's not a complicated thing. If your experiencing hard time connecting to the internet please make sure to check on the error. Based on what you have mentioned it says that you need to check the security setting. You may try following the steps below for the basic configuration on how to connect your PSP to your router.
1. First step is to make sure to turn on your PSP as well as the wireless/WLAN switch. 2. Then Navigate to " Network Setting". 3. Select "Infrastructure Mode". 4. Now Select "New Connection" and Name this connection as you deem appropriate. 5. Navigate to "WLAN Settings" Select "Scan". 6. Your router should now be listed. 7. Please go to "WLAN Security Setting". If you did not select encryption in ROUTER SET-UP, then leave the option as "None" 8. But if you selected encryption in ROUTER SET-UP, then select the appropriate WEP, or WPA. 9. Then navigate to "Address Settings". Select "Easy" 10. Go to "Setting List". Verify that your settings are correct. 11. Navigate to the next screen and press X to save your settings. You should get a message that says "Save Completed. Test Connection". Press X. 12. You should get two quick display messages. The first should say "connecting to access point." The next should say "obtaining IP address".
From this point you already established a connection and using your PSP you can now browse the net.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Slim...
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
Why i can't access internet on psp
1.] Check if your wlan switch is turned on...
2.] Have your console scan for wifi connection through infrastructure mode in the internet settings option...
3.] If problems persist... You may have a defective wlan switch...
Oct 09, 2010 | Sony PlayStation Portable (PSP) Console
Is it true that psp3004 is not yet game
If you have a WLAN connection then switch it on and turn on the 'WLAN' toggle switch in your PSP 3004. Then access PSP via the WLAN. There's a icon for Downloading games from the PSP. Open it and connect through the WLAN to the internet.
If you not have a WLAN then go to "http://www.freeforpsp.com/" or "http://in.playstation.com/psp/games/" from your PC Browser and just download and transfer it into your PSP's Memory card. Or buy a Game Disc.
Hope, i gave you much details.
Thanks n Regards
Vineeth K.
Jul 08, 2010 | Sony PlayStation Portable (PSP) Console
How can i connect my sony psp online
Turn on your WLAN switch....
Go to Internet Browser....
Network Connection> [New Connection]> Scan> now *select an access point*,> *now check the info*...; SSID>WLAN Security Setting>net password (if required)> Address Settings; Custom> IP Address Setting; Automatic>DNS Setting;Automatic> Proxy Server;Do Not Use(your choice)> Internet Browser; Start>Enter the connection name; (your choice)>Setting List; *scroll through to see if the info are correct*> Press the O/X button to save settings.
Select connection....... DONE!
Oct 22, 2009 | Sony PlayStation Portable (PSP) Slim...
How can i put internet in my psp?
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
  8. Select a connection and press icn_btnx_color.gif.
  9. The web page will be displayed.
  10. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Highlight icn_settings.gif(Settings) from the home menu.
  3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
  4. Select Infrastructure Mode and press icn_btnx_color.gif.
  5. Select New Connection and press icn_btnx_color.gif.
  6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  9. Confirm the SSID and press the right directional button.
  10. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  11. After entering the security information, press the right arrow button to continue.
  12. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
  13. After selecting the address setting method, press the right arrow button to continue.
  14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  15. To save the new connection, press icn_btnx_color.gif.
  16. To test the connection, select Test Connection and press icn_btnx_color.gif.
  17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Internet wlan
get to an access point, configure the settings and you;re done. however make sure the lan switch (hardware switch to the left or above for the slim PSP) is enabled.
Mar 12, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
88 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
