Check trans - Computers & Internet
    Brigadier General:
  • 7,191 Answers
Please elaborate the problem providing us with more details and the brand / model number.
Kindly reply to this post with the details. Thanks for using FixYa
Posted on May 08, 2010
Dodge ram
which oil trans or engine oil? if trans, check the fluid line fron trans to radiator, trans oilpan gasket, if engine oil check oil filter, oil presure switch
Jan 10, 2012 | Cars & Trucks
My W5A51 trans in my Diamante is slow to change allowing it to Rev Quite high when it is cold and it sometimes slips out of gear when cornering around turning circles. I have checked the trans fluid level...
when you check the fluid do you allow the trans to come to operating temp and check it with the engine running and trans in neutral, don't forget to set your E-brake or block the wheels from rolling. you checked the fluid in this manner it would be my guess that the clutches inside the trans or the belts in the trans are slipping, it could also be something as simple as needing a trans service, new fluid and filter.
May 22, 2011 | Mitsubishi Diamante Cars & Trucks
Trans wont go in gear but parg engine runs fine juat wont go in gear
standard shift you need to adjust clutch or replace.check trans oil
auto trans check oils, adjust or rebuild trans. / torque converter.
Apr 02, 2011 | 1992 Pontiac Grand Prix
Ford focus will not engage gears, it will not shift into reverse or drive...
there could be any number of things causing this problem. start with the easy one, check your tran fluid, you will have to let the car warm up and check it while the car is running. p.s. locate the trans dip stick under the hoodwill be on the side of trans. if the fluid level checks good check you trans shift linkage make sure it is attached properly. you may need to find some one to help you with this. if it is ok your trans filter may need changed. you will have to remove the trans oil pan for this(it can be messy) you may want a shop to do this if you have'nt done it before, next cause could be a computer malfuction with tranny sinsors or you trans bands are wore and need to be replaced.
Feb 26, 2011 | 2004 Ford Focus
1994 trooper trans light blinking took it in shop did a trans flush filter,gaskit and tran oil change. but this is the thing trooper misses and tran hold back but when shop checks computer reads nothing...
check out the neutral saftey switch on trans, if its reporting unknown gear on scanner while moving t bar it wont know what gear to be in and give you similar problems, also has oil been leaking into switch before?
Feb 17, 2011 | 1994 Isuzu Trooper
I replaced the trans in my 1991 ddge stealth es and trans fluid came out where do i putit back in at?
You add trans fluid through the trans dipstick tube (NOT the engine oil dipstick). Check your owners manual for the proper method to test the level, most cars lately you check the level with the trans fully warm, in Park, engine running, parked on a level surface. (Set the parking brake, block the wheels.) You will need a long funnel, available at any auto parts store. Do NOT overfill the transmission, as this will cause damage to it.
Use the correct type of trans fluid, check your owners manual.
Aug 24, 2010 | 1991 Dodge Stealth
Replacing transmission fluid
do not do trans flush if car has over 100,000 miles and has never been flushed. if its under 100,000 or has been fushed before it is an easy job. there is a drainplug on trans pan. take out drain fluid. new trans filter will come with new trans pan gasket in most cases. remove trans pan, fliter is behind trans pan
Feb 21, 2010 | 2006 Ford Explorer
Check trans light blinking
have it checked out by a quality trans shop amco's always a good chpice good flashing light indicates transmission malfunction or engine problem and the trans has gone in to safe mode but if no check engine or service engine light prob the trans
Feb 18, 2010 | 2002 Isuzu Axiom
How do I check automatic trans fluid in a 1997 Honda Civic? In the past I've always check fluid with the car idleing in park at normal operating temperature. But the Honda dealer is telling me to check it...
That's because you don't understand how a Honda trans works. Think of it as an automatic manual trans, that is Honda's trans are the only one's where all the gears are constantly meshed. When a Honda trans shifts, it engages that specific gear. All the gears are meshed, a Honda trans engages a clutch pack which gives power through that specific meshed gear, just as you would if you were shifting a manual trans. Now since all the gears are constanly meshed, they are inmersed in trans fluid, If you check it while it is running, It will show less, plus the fact on some Honda models the gears are right next to the dip stick and if your not careful, the dip stick can get pulled into the gears and destroy the trans.
Nov 09, 2009 | 1994 Honda Civic
Computers & Internet Logo
David Payne
David Payne
