Question about Pure Digital Flip Mino Digital Camera
My NewBrand FLIP MINO HD2 once switched on and after having pushed red button ( recording ) is now blocked ! No responding to any command or doing any action ( no recording, no display, red light rechargin battery always on, no chance to switch off the device ! HELP ME PLEASE
  • 4 Answers
Return it for a refund! i bought one, it did the same as yours. i returned it and bought the 2nd one. It did the same as the first one (and the same as yours.)
It is a piece of junk. Supposedly the previous Flips were good, unfortunately, I didn't have the previous models so my experiences only are bad.
Posted on Aug 10, 2010
Flip video instruction manual
Had the same problem. After trying everything, this worked:
From a command prompt, list directories. You might see one called ".Trashes\501" -- this is the directory where I found all the videos hiding that we tried every trick in the book to delete. If you see video files in this directory, simply delete them using the command prompt. Then exit the command line interface and check your camera. You should have a full 60 minutes of recording time restored.
Hope this works for you!
May 01, 2014 | Video Cameras
F lip mino hd camcorder wont turn on. red recording light came on when charging but when disconnected from laptop recording light stays on and wont switch on
Same thing happend to me when i baught it brand new, just follow wat i say step by step, look at the bottom of your flip and there is a tripod hole and in that hole is an even smaller hole, take a papper clip and unbend it to make it straight,(thats what she said) then stick it in the small hole until you hear a click like a little button cause there is one in there, just hold it down for 5-8 seconds and do it again for 5-8 seconds then plug it in to ur computer, let it charge and you will be video tapin stuff in no time :)
Dec 29, 2010 | Pure Digital Flip Mino Digital Camera
Flip recorder time
It says in the bottom of screen red when recording green when on stand by
Nov 26, 2010 | Flip Video Mino Camcorder
When I try recording with the camera a message appears stating that the HD is full. That makes no sense because I transferred everything to the computer what can I do to solve this problem Thnaks for your...
Did you empty the flip? That might be your problem. Just because you uploaded it does not mean its erased. Try reseting it if you have the mino get a pin an push the button in side of the tripod screw in. If you have the ultra take out the batteries for a second then put them back in. Or call flip support at 8882226689
Jul 27, 2010 | Flip Video Mino Camcorder
Just bought a flip mino HD. It wouldn't turn on,
Figured it out! Hold power button down for 10 seconds and my Flip HD works!
Jun 12, 2010 | Pure Digital Flip Mino Digital Camera
My flip mino HD has been charging for 3 hours and will not turn on. I've tried resetting the battery and it still won't turn on
Is it plugged in directly or with a USB extension cable? Some cheaper cables are not sufficient to charge it.
Mar 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Jan 26, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Hd stopped working. USB light blinking, but red light not on. Cannot start, record seems "dead". How do I restart?
Im guessing press the reset button the bottom, with a paperclip and hold it for 3-5 seconds and try it again, it night take a few trys but it has worked for me a few times... worth a shot ?
Dec 25, 2009 | Pure Digital Flip Mino Digital Camera
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Frozen screen on recording
There's a hidden Reset button at the bottom of the Flip Mino. At the bottom of the camera, there is a screw base a tripod. Inside of that screw base there is a little hole. Use a paperclip and poke it into the hole. Hold it there for 7 seconds. You may need to repeat this process 3-4 times. This should shut down the video camera.
Mar 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Pure Digital Flip Mino Digital Camera Logo
193 people viewed this question
Top Pure Digital Cameras Experts
Are you a Pure Digital Camera Expert? Answer questions, earn points and help others
