Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Rewind a husqvarna chainsaw pull cord spring - Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Brigadier General:
  • 4,090 Answers
Ohh ! yes it can be done But with a lot of difficulty and many zapped fingers as it springs back under pressure
please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
Where can I get a spring for my saw ?
How to Replace the Pivot Spring on a DeWALT DW708 ...
? 6:48
https://www.youtube.com/watch?v=xz3EPWHjj0A
Aug 9, 2012 - Uploaded by eReplacementParts.com
Dammaged pivot springs can prevent your saw's cutting head from staying upright and, as a result, cause a ...
Replacement Parts ' Pruners ' Loppers ' Saw Blades ...
coronatoolsusa.com/replacement-parts.html
Items 1 - 12 of 268 - $0.00 (0 Item). You have no items in your shopping cart. MyAccount · Login ... Spring for AG 4980SS. 4980-5. $8.53. Spring. 6310-5C. $7.11 ...
Shop for Where can I get a spring... on GoogleRecoil Starter Spring Homeli...$10.00eBaySpring Starter Chainsaw Ech...$4.99eBayHomelite 26lcs, 5?20, 5?30n, 6...$24.00eBayMcculloch Chainsaw Spr...$13.99eBay5x Husqvarna 362, 365, 371...$19.75BonanzaSearch ResultsHow to rewind a pullstart spring - YouTube? 5:05https://www.youtube.com/watch?v=qTcL3_3leTkMar 13, 2010 - Uploaded by lenniepincherIf you ever need to rewind a un coiled pullstart spring. This might help you. It took me ... First pull of my chain ...Chainsaw Rewind Spring Replacement - Echo ... - YouTube? 3:38https://www.youtube.com/watch?v=oqcjL7W0XMAFeb 18, 2013 - Uploaded by RepairClinic.comThis video provides step-by-step instructions for replacing the rewind spring on Echo chainsaws. The most ...
Dec 12, 2015 | Garden
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
HUSQVARNA 326E PULL CORD WANT TURN SHAFT
could be the pawl catch on the crank shaft is not working properly, if this is an easy start model, there are two springs and two pulleys to inspect. usually second spring is the problem.
Jul 25, 2014 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Hasqvarna mod 55 pull cord will not rewind. How do I repair or replace the spring?
The 55 spring is supplied in a black plastic keeper, its just a matter of removing the centre screw, remove the pulley, the spring is then captive in the keeper, carfully ease out ( always wear saftey glasses ) you can now drop the new spring in.
Sep 30, 2013 | Husqvarna Chain Saw Models 51, 55
Can not pull cord all the out to start the saw
Sounds like the pull cord has become trapped round the spool. Remove starter housing and unwind the pull cord manually off the spool. Then wind the cord back on by hand. Be careful because the spool will be under tension from the rewind spring.
Mar 18, 2013 | Husqvarna 240 Chainsaw 16" Bar -free...
VIKI PR-GS5200 - I need to rewind the pull cord so it will work
It maybe the return spring behind the pulley has broken, be very carefull when removing the pulley as the spring can easilt fly out, new springs are in keepers so are very easy to fit.
Feb 29, 2012 | Garden
How do i replace pull string on craftsman 20/14 chainsaw
Remove the cover containing the cord rewind mechanism, untie the cord's knot in the center of the mechanism and remove the old cord by unwinding it from the pulley. Thread the new cord through the hole it goes through on the outside and wind the recoil mechanism so that it has sufficient spring tension to rewind the new cord. Use something appropriate to immobilize the pulley while you thread the cord through the center and tie the knot. Slowly allow the pulley to retract and wind the new cord onto it. Replace the cover. As an aside, sometimes when the cord breaks and the pulley snaps back quickly, the rewind spring can break.
Jun 24, 2011 | Garden
The pull rope will not rewind. How do I reset it?
The cord should be removed from the spool entirely, then wind the spool spring CCW for a number of turns making sure the spool can be turned for about 6 turns more (during start). Wedge the spool so that it can't unwind the spring again. If the old cord was about worn out, replace it with fresh. Melt the cord end somewhat so that the knot won't pull out, then tie an overhand knot in the cord end. Feed it into the inner retainer on the spool, then thread the cord around the spool 5 or 6 times in a CCW direction. Once wound, feed the loose end out of the cord port, slide the pull handle on, melt the cord end, and tie an overhand knot on it. Stuff the knot into the handle and release the wedge from the spool so that spring tension pulls the cord tight. Pull the cord out several times to make sure nothing interferes with cord and mechanism, then install on the saw and check the start operation. The spring should never bind-up when the cord is fully extended. Hope this helps!
Jul 25, 2010 | McCulloch Garden
How do i get the pull cord spring back in on a
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Nov 22, 2009 | McCulloch Garden
Pull cord stuck in the out position
this can be caused by sevral things inside the pull cord hub assembly. examples: Dirty inside & needs taken apart & cleaned. something logged inside, plastic spool tabs broke, spring/s broke, levers broke or any of these items could just be to worn. replacement parts should be available.
Oct 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
418 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
