Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Conflict following installation of a wireless access point
Conflict following installation of an aruba wireless access point to a wi fi d link.
The pc crashed internet lost. Windows os affected.
re installing broadband and IP adress resolved internet access but windows os still affected.
    Genius:
  • 1,354 Answers
If your yousing router and your windows is crupet no metter with your modem setings it will ther becoz your setings will be in your modem only not in pc
if your using with dailup conection then only it will sak u user name and password only
Posted on May 08, 2010
WiFi disconnects
the problem with your AP , change it
Mar 14, 2014 | EnGenius EAP-3660 802.11b/g Wireless...
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
How to configure a D-link access point DWL-3200AP
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 02, 2010 | D-Link AirPremier DWL-3200AP 802.11g/b...
Enable security on wireless network
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
May 06, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I forgot the password of my dwl-900ap+ and can not connect additional pc to the wlan. Help
http://192.168.0.1
or
http://192.168.1.1
Jan 10, 2010 | D-Link Air DWL 900AP (DWL-900AP) 802.11b...
How can i turn on wireless for Dell M1210?
For that first turn on the wi fi switch on laptop.
Then right click on my netowrk places then make sure your wi fi adpater is there enable it then right click on it then click on biewe available networks.
If it not show netowrk then you have to enable wireless in router.
For that first connect wi fi router to computer then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
Type user as "admin" and password as "admin" or blank or "password"
then go to wireless and enable it .
Then save settings and restart router then check.
Make sure wi fi driver is installed in laptop.
Let me know if you need more assistance.
Thanks.
Oct 20, 2009 | Dell XPS M1210 Notebook
WIRLESS NOT WORKING
First turn on your wi fi switch on laptop.
Then go to my netowkr places proeprty and make sure your wi fi network adapter driver is installed and enabled.
Then click on view available wi fi networks then check you get signal form wi fi router.Then it works.
Let me know if you need more assistanse.
Aslo you can check in router that wireles is enabled in router?
For that connect your wi fi router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
typoe user as "admin' and password as "admin" or blank or "password"
then check in wireless settings that it is enabled.
Thanks.
Sep 24, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
177 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
