Panasonic WORKiO DP-1520P All-In-One Laser Printer Logo
Anonymous Posted on May 08, 2010
Panasonic DP-1520P printer driver for Windows 7 64-bit
I am using a computer with Windows 7 64-bit and the printer is Panasonic DP-1520P. It is connected as I can print a test page from the printer properties, but when I go further into "preferences" the pull-down bars for paper size, media type, and paper source are blanked. I run into the same problem when I try to print from PDF or Excel file. There may be a compatibility with the OS, or I may not have the correct driver. Please assist.
  • Anonymous Aug 12, 2010
    The users of this website should note that the answer from the expert would lead you to download a software called Driver Detective, which after you download and install, identifies the status of all the drivers on your computer. When you request to update the drivers, Driver Detective ask you to register it - and this is not a free software!
    I don't want to say that this is a scam, but they certainly wouldn't give you a straight solution to the problem you address before you pay for their software. There is no free lunch after all!
    give you a straight solution to your problem unless you pay
Khurram Shah
Level 3:
  • Panasonic Master 10,322 Answers
  • Posted on May 08, 2010
Khurram Shah
Panasonic Master
Level 3:
Answers
10322
Questions
0
Helped
1468361
Points
20234
1st You download Printer Driver. Panasonic Printer Driver For Windows 7 After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
celia Alfredo Tembe
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 19, 2014
celia Alfredo Tembe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12501
Points
3 Related Answers
Anonymous
  • 99 Answers
  • Posted on Dec 09, 2009
SOURCE: whenever i switched on the panasonic dp-1520p it
Ad paper mean paper not response your printer.it is problem paper sensor,it may be displace,check and clean it.
Anonymous
  • Posted on Nov 12, 2008
SOURCE: Panasonic DP 1520P - wont print
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
Anonymous
  • 100 Answers
  • Posted on Jun 14, 2010
SOURCE: Printing VERY slow for PDF documents on DP-8045
well if you really needed a pdf printing concern, you may add an option which is Multi Page Description Language Controller Module. the post script printing language will be activated and you won't have to wait for the computer to process the pdf document on a gdi format (microsoft). what's more is that your mac computer can also directly print to the dp-8045.
that's it
Panasonic 1520dp
please help me how to fix my PANASONIC DP-1520p printer, it always getting OFFLINE in my computer, it connects in ROUTER thru broadband. but it works fine in other computer. i tried to fix the connection many times. but it seems that all the wire are fine. pls. help me what else i need to do. tnx!
2answers
I need drivers for my Panasonic WORKIO DP-1520P Multifunction 15 PPM Digital Laser Copy Machine MFP Copier / Network Printer
Click here Click on above link and download driver for your os and install. Let me know if you need further assistance. Thanks for using FixYa.
I need printer drivers for my panasonic dp 180 - i have windows 7/32 bit
you can go to this website and download the beta version
http://panasonic.net/pcc/support/mfp/dp-180/pdl/download.html#01-6
hope this help
Mac Driver
http://panasonic.co.jp/pcc/products/en/mfp/download/dp-1820/ps/eng.html
here is where you can get a mac driver. but you need a PS"post script" key installed"little electronic board" before you can use this driver. good luck.
3helpful
5answers
All the best...
33helpful
3answers
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
