Question about Garden
Digital Multimeter Mastech, verses Fluke, Unfortunately I damaged my good old Fluke 87-3 when I measured a 3 phase motor supply while still in ohms mode, one of those o-**** moments when you hear the meter freak out and know without even looking at it. Still works but brain damaged and I don't trust it anymore. Anyway looking at various meters on the market and came across this mastech meter on ebay item 200461965472, I know its not a Fluke, but I like the features it boasts and of course the lower cost than Fluke, has anyone used this brand? Any good? One thing I like is speed are these fast or is there a delay like most meters other than Fluke. I would like to hear from someone who has actually used one of these or makes. Also looking into PC based meter/O-Scope/Function generator where the PC or laptop is the display/control with a interface box with in/outs. Has anyone had experience with these and can recommend makes, models.
  • 12,061 Answers
I have had experience with both systems you are inquiring about. personally, I think you should get a Fluke, NOTHING even comes close, as I am sure you are aware, any extra cost is soon made up for by features and reliability. I haven't had very good results using Virtual Instruments, they are OK, but.. very cumbersome, in use etc, you just cannot beat a "scope. Now I really recommend the Fluke Scope meter, they are just awesome, in every way.. I have had VERY good results and a cheap repair, when I sent a damaged meter back to Fluke, they reconditioned it and calibrated etc, and the cost was as i remember very reasonable, for what was done, so perhaps you would like to entertain that thought. You can always ask for a "Quote" before allowing repair to proceed, that way you have little to loose. There are many meters and instruments out there, and as you know, a man is only as accurate as his equipment, and I always recommend Fluke, as they are simply the best. Possibly a bit Pricey, they are always worth it. So go with your first instincts, which were indeed right on the money, Fluke all the way. As I said have a look at the Fluke Scope meter, and possibly treat yourself to a wonderful piece of equipment you'll fast wonder how you ever did without it before.
Posted on May 12, 2010
  • 409 Answers
I have not used the mastech meters, but I do know that all Fluke meters are tested to withstand 1000 volts on ohms scales without damage. I own an 87 and have accidently tried to test voltage on the ohms scale with no detrimental effects. Do not scrap the Fluke, no one makes a meter that is as good as or better than Fluke.
Posted on May 10, 2010
  • 8,404 Answers
I am certain I answered this i the free section when I said you should avoid bargains in certain areas ... heart surgery, fire extinguishers, life boats and volt/ohm multi-meters just to name a few. Stick with the Fluke, a known good product.
I also suggested you check inside to see if the fuse did its job and maybe, that is all that is wrong with your fluke.
Thanks for using FixYa.com
  • A Miller May 10, 2010
    I see you marked me 2 thumbs ... still I'm sticking by my guns ... why purchase a second rate unknown meter when you are accustomed to traveling first class ... Stretch, get yourself a new Fluke ... or maybe yours is repairable.
    Consider it my friend ...
    Thanks for your interest in FixYa.com
No ohms on 179 fluke meter
check input protection (thermistor (black components - first in line at Voltage terminals should be around 1kOhm, next is 2W resistor = 1kOhm and then 3 varistors (blue) open or very high ohms).
Aug 09, 2013 | Fluke Networks Fluke 179 Electricians...
Need a user manual for Voltcraft 95
http://www.produktinfo.conrad.com/datenblaetter/100000-124999/124603-an-01-ml-VOLTCRAFT_VC_870_DMM_de_en_fr_nl.pdf
Apr 05, 2013 | Fluke Networks Fluke 87-5 Digital...
How to set mastech multimeter to read small batteries
Set the multimeter to a DC voltage range that includes the voltage you wish to test. Connect the probes with the correct polarity and observe the reading
Mar 16, 2013 | Mastech 19-range Digital Multimeter Dmm...
Mw612
The Motor Controller has detected excess current in the motor or electronic
switches. This fault has occurred momentarily.
Primary Source: Wiring.
Action: Check the wiring connections from the Motor Controller to the Stator
and the Rotor Position Sensor.
Secondary Source: Motor.
Action
1) Measure/check the motor harness, connectors and motor for shorts. This can
be done by taking a resistance measurement between phases of the motor
harness at the Motor Control module end. Nominal resistance should be
around 12.2 ohm for Phase 2, 3 & Phase 4. For Phase 5 and 6 Smart Drive
the nominal resistance should be around 32 ohms.
2) Check the Rotor Positional Sensor, Stator brass bridge terminal point and
associated harness for water, mechanical damage or corrosion.
Tertiary Source: Motor Controller module.
Action
If all the above show no signs of fault then replace the Motor Controller module.
Also check for water leaks from the cooling chamber or valves that could possibly
come in contact with the Motor Controller and fix the leak before replacing with new
Oct 19, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fluke 87-5 affiche F8
F8 Error - invalid model -you will have to return to Fluke for service
May 16, 2012 | Fluke Networks Fluke 87-5 Digital...
Fluke 87-5 affiche ERREUR F8
What size of cable do use to ware a three phase 32 amp isolator
you need a 8ga wire if you are going to run a 32amp power, good luck
Sep 05, 2011 | Fluke Networks Fluke 179 Electricians...
Garden Logo
346 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
