Question about Gateway FPD2185W 21 in. LCD Television
Can anyone please tell me where to get an on/off Sw for my Gateway Mod # 2100 Ser # MQ17250N00391, HD LCD monitor? It's a simple on/off push button SW. Gateway has been so KIND refusing to sell me the SW. OR...would a technician help me correctly bypass the SW by jumping the needed 4 wires at the SW plug lead to the monitor so I won't need the SW anymore? There are only 4 small wires so it can't be all that hard! I just need to know which wires to jump correctly. The colors are: yellow - brown - green - black Or they are yellow - black - green - black. Hard to see they are so small. I realize the monitor will forever be constantly on, NO PROBLEM. Thanks so much. Tom
  • 36 Answers
Black and yellow wires are for the switch
yellow and green are for the LED
Posted on Dec 15, 2010
My Gateway monitor scrolls through settings on right side of screen
Button may be stuck pushed in, use q-tip/alcohol to clean around the button.
Dec 23, 2012 | Gateway 24" Widescreen Flat Panel TFT LCD...
I don't see a volume button on the gateway hd 2100 monitor. Is there a way to turn up the volume without having an attachment?
use your operating system volume controles or possably your keyboard has a volume control on it.
Jan 16, 2011 | Gateway FPD2275W LCD Monitor
What are all the plugs and buttons for on my gateway 2100 monitor and can it be used as a tv or just monitor for computors i just need to buy power cord
yes you can attach several inputs to this monitor,
the buttons are for ajusting the screen settings and setting the inputs from that tv
Sprint6@zoominternt.net
Oct 10, 2010 | Gateway FPD2275W LCD Monitor
I have a Gateway HD Monitor Model 2100. The screen flickers and turns off. I can cycles the on.off button and it comes back on, only to flicker and turn off later.
Either you have a problem with the back light or inverter.
When you disconnect the unit from its signal connection, you should see no signal input message.
If the unit flickers and then go out, while disconnected, you can rule out the video card and assume it is the back lights or inverter.
90% of the time, it is the back lights.
Nov 24, 2009 | Gateway FPD2275W LCD Monitor
GATEWAY 2275 LCD MONITOR WENT OUT, WHEN PLUGGED
This could be due to a bad power supply inside the monitor witch is replaceable for like $25 bucks all you got to do is unscrew off the back undo a few cables and put in the new supply.
I hope this helps you in the repaire process if its under warrenty please seek warrenty guidlines.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Gateway FPD2275W LCD Monitor
S-video input from Panasonic MD830 S-VHS to Gateway 2100 monitor causes monitor to intermittently project signal or turn off. Will a S-video to VGA converter solve this problem or is there a problem witth...
It seems the the monitor is not supporting the resolution you have selected in display settings of operating system. therefore please minimize the resolution of display then check your monitor. hopefully it will work
Apr 08, 2009 | Gateway E-2100-V2 (E2100V2-D) PC Desktop
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
144 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
