Question about Sony MDR-V150 Professional Headphones
The spring system for adjusting headphones broken
The spring system for adjusting headphones to fit the size of someones head is broekn
    Sergeant:
    Champion:
  • 236 Answers
Buy another set and then return your mangled set
Posted on May 08, 2010
How do you service and adjust the front fork suspension... Way stiff!!
Fork adjustment varies from bike to bike. Some have no adjustment at all, some have screws that you turn in and out, some are adjusted/aided by air. Some people change the weight (viscosity) of the fork oil, fit firmer or looser springs etc. Fork adjustment and settings depend on the riders size, handling and bike style so there really is no "stock setting, one size fits all".
What you consider way stiff may be ideal for me but too soft for someone else.
The best way to find out how to adjust the settings (if it is possible) is find a forum online relating to your bike as adjustments of this sort is a fairly hot topic of discussion.
I hope that is of some help.
Aug 26, 2015 | Motorcycles
What size is the lower adjusting bolt on the alternator & can the fan belt be easily adjusted
no engine options stated,
cant fix engines or get help if you dont even know what is there..... the EPA sticker under hood tells you, or post the VIN. the VIN has engine codes.
3.2 L 6VD1 SOHC V6
3.2 L 6VD1 DOHC V6
3.5 L 6VE1 DOHC V6
3.0 L 4JX1 TD I4
3.1 L 4JG2 TD I4
did you try a 13 or 14mm wrench or socket yet?
Aug 08, 2015 | 2000 Isuzu Trooper
Are one-size-fits-most Helmets any good or should I prefer a more fitted helmet?
These types of helmets are good because they can be adjusted. They have a custom fit system that allows you to adjust them to different head sizes. This way you can actually have 1 helmet instead of 2 in case that you and your family members are not rafting together.
Feb 03, 2013 | Boating
I hear a rattling noise under he car when i hit bumps?
The most common cause would be the exhaust system has a broekne pipe hangar. Any muffler shop will inspect this for little or no cost to you.
Jun 29, 2012 | 1999 Cadillac Escalade
Can u adjust the timming chain on a yamaha xj 600 1998 model
The XJ600 has a self adjusting timing chain tensioner, although it's robust enough, like the previous post say's they can stick. To remove the adjuster look at the back of the engine on the cylinder head, the tensioner is there, two bolts hold it on one above and one below. to remove the tensioner there is a spring tensioner in the centre of the unit, undo this with care it hold the pressure spring in place on the plunger. Now remove the retaining bolts very carfully, equal turns on each bolts (do not take one out fully, leaving the other in place fully tight).
Once off the engine DO NOT ROTATE the engine. The tensioner should move freely, although there is a rachet system that locks it out, if it moves out freely then it's fine. To re-fit the tensioner release the tensioner make sure it's adjusted fully inwards and use a fresh gasket. The tensioner only firs one way, if it won't fit don't force it and it can be broken easily. Tighten both retaining bolts evenly and per the removal. Re-fit the tensioning spring and retaining bolt (do not over tighten) the plunger is self adjusting from here.
Mar 13, 2010 | 1998 Yamaha XJ 600 Diversion S-N
Roland XP 50 Head phone not working
Make sure that the level of the headphone out put is open. Make sure it is on manual adjustment and no auto level. And test your headphone on a other device to clear that your headphone is not broken. If all these options are correct you headphone pre amp of the XP 50 may be damaged or broken.
Mar 07, 2010 | Music
No audio thru the speakers, headphones only
you answered your question. let me explain: the head phone plug is a switch- that disconnects the speaker and only allows sound to the headset. the switch is either broken, loose-wire or dislodged.need to get inside the unit, You could of course get creative. put an adaptor to the headphone jack;the adaptor can now allow you to run wires to the speakers. adaptor is avail from radioshack-same size as on the headset.
Mar 04, 2010 | Philips MCM530 CD Shelf System
Need Replacement rubber band for wireless headphones JW160R
I to broke mine and couldnt find a replacement part anywhere! called xbox and every game store and no one sells them. What i did was go on Ebay and bought a Broken AS IS Headset for $8 and took the earpiece from that and put it on my working earpiece. Thats the only way to get a replacement part trust me!
Mar 26, 2009 | Audio Players & Recorders
Head phones adapter plug
There are three sizes of standard headphone plugs:
TRS audio jack: 1/4"
mini: 3.5mm (~1/8")
submini: 2.5mm (~3/32")
According to specs, your RCA system should accept the 3.5mm jack.
Although the manufacturer can pick any option, most large headphones would have the 1/4" and/or 3.5mm jacks. Small earbuds are more often 2.5mm.
RadioShack, or similar store, would have adapters to convert between these sizes.
Apr 21, 2008 | RCA RS2130i Shelf System
Sony MDR-V150 Professional Headphones Logo
109 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
