Question about Xerox DOCUMATE 510 Flatbed Scanner
Acrobat could not communicate to this device - Xerox DOCUMATE 510 Flatbed Scanner
  • Anonymous Nov 30, 2008
    I have the same problem. Acrobat 7.0 works fine, but Acrobat 8.0 crashes. There are work arounds, but they don't work well if you want to use Acrobat's "Scan Both Sides" feature, which reassembles the pages in correct order when scanning is complete.
Adobe acrobat configuration error 1
you need to uninstall ,format device and re-install again it will work.
Feb 09, 2013 | Adobe Acrobat X Pro
Adobe acrobat configuration error 6
Jan 20, 2013 | Adobe Acrobat X Pro
"Pick..." List on the Calculate tab of Text Field Properties in Edit field mode in Adobe Acrobat 10
http://adobe-flash-player-non-ie.soft32.com/ 11.4.402.278Free Adobe Flash Player is a cross-platform browser-based application runtime. Hope this helps.
Jan 18, 2013 | Adobe Acrobat X Pro
Cannot edit text in acrobat x pro
you need to uninstall ,format device and re-install next put your characters on the acrobat x pro file you can do it by go c drive program-file,acrobat x pro click it add file again it will work.
Jan 08, 2013 | Adobe Acrobat X Pro
Acrobat x pro serial number
You will need to contact Adobe directly in order to get an authorized serial number. This will also help prevent you from having any authorization issues in the future.
Jun 01, 2012 | Adobe Acrobat X Pro
My Acrobat Pro Extended stops working every time I open
Apr 22, 2012 | Adobe Acrobat 9 Pro Extended for Windows...
I have downloaded books from Barnes and Noble to my computer, now I don't know how to get them to me ereader. When I plug it in it just says emode and I don't know what to do
Observe the requirements of computer document decoder programmes. For example, adobe acrobat reader performs functions either capturng to display media from several devices. Once installed, adobe acrobat reader on the computer, documents that are instaled or introduced from elsewehere that require decodes eiher as encoded on various formats are decipherable. Ascertain either with computers on network connections to downloader the latest version of adobe acrobate reader. While on the internet, acquire the most compartible to computer. Significant notes includes that adobe acrobat likely requires program components either as flash media players, to complement to attain multimedia experices on computers that capture resources in various formats.
Feb 21, 2011 | Computers & Internet
When i uninstall acrobat x pro from add or remove program, then it still happening acrobat active x in common file. how do i unistall completely.
remove from c drive program file + remove from control panel add remove program, remove from c drive all user
Jan 31, 2011 | Adobe Acrobat X Pro
Xerox DOCUMATE 510 Flatbed Scanner Logo
1,208 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
