PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
CD DVD Code 41
By Kyleandrew on Mar 27, 2008
It all sorta started once I used Tweak UI and at the same time I also started using the flash drive. In both the Presario lap - with one dvd and a Dell Demension desktop with two dvd. Both units issued Code 41, the correct drivers are listed. But the computers are not successfully entering a drive letter. What cha think?
Comments:
Mar 29, 2008
- APPLAUSE, APPLAUSE: My system did not allow me to delete the key but your refering to the Microsoft site had the Guided Help which did it auto. Wow, I knew this was a simple issue, but when I once went searching thru Microsoft with Code 41 got nowheres!
I really appreciate your fine guidance.
Kyleandrew
Apr 02, 2008
- Applause, Applause. You did a fine job Mike!
Well it sure was impossible to find the Microsoft link on my own when searching the Code 41 issue! I did use the auto program Micosoft provides since I was unable to touch my registry. It's kinda amazing they set that up.
Same Problem
Apr 22, 2008
-   computer wont detect cd drive code 41-   Guest
Best Solution
posted on Mar 27, 2008
Very Helpful)
MDoe
Rank: Guru
Rating: 89%, 311 votes
Hi
This is a known issue. A lot of burning programs, and tweak tools have a habit of screwing Window's Registry, XP's in particular.
To fix the condition we need to delete a few Windows Registry Keys. As always be careful with Windows registry.
CAUTION: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Use Registry Editor at your own risk.
To resolve this behavior, follow these steps:
Start Registry Editor (Regedt32.exe).
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software.
Restart your computer.
Check Micosoft Knowledge Base Article 314060 - http://support.microsoft.com/kb/314060/EN-US/ for more info
Regards
Mike
Comments:
Apr 28, 2008
- Hi
Thanks Kyleandrew for the reply and rating.
Mike
Was this helpful?
Yes
No
Solution #2
posted on Oct 07, 2008
Not Rated)
irelandredfo
Rank: Apprentice
Rating: 0%, 0 votes
i have an aspire series 3682 laptop computer. I've upgraded to window's Vista home basic from window's xp and since then my problems began. I not very clever with computers and quite frankly most of it baffles the hell out of me. The CD drive,DVD capabillities are totally gone.I've tried to Download the guided tour on microsoft's website hhtp.//support.microsoft.com/kb/314060/ and it has failed some how my computer has only two drives C and D. help
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
How to choose a ebook reader.Comparison of performances between different models
Answer
I can not get graphics screen resolution high as i need so pls answer me thanks
Answer
my set is dead no power supply at all the adapter is good so the battery but the laptop still dead... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
