Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
HP Officejet 8500 A909a Fax using magicJack VoIP
How can I fax using magicJack VoIP telephone service? I've been able to send ONE 3-page fax successfully. All the rest, I get error codes 344, 345, 346, 350, and 387. I've tried all three transmission speeds (9600, 14400, 33600) with and without ECM. The AiO is networked through my router for printing, but is connected directly to the magicJack dongle for phone service.
  • 100 Answers
After many attempts I was finally able to send 10 pages with no problem.
1. Set fax speed to lowestby selecting: Fax setup; Advanced Fax Setup - Fax Speed -Slow.
2. Remove telephone jack line from the MJ and plug fax machine directly into the MJ. Plug phone line into the bottom phone jack port on the HP 8500. This way both phone and fax will work without having to unplug it.
3. I was unable to fax to a fax line that went directly into someone's computer - but when I sent it to a regular fax machine it worked fine.
4. Don't forget with MJ - you have to always enter the area code even it's a local fax.
Hope this works for you too!
Posted on Oct 08, 2012
Hp officejet pro 8500 a909a all in one series. unable to fax. message states: image on fax send report is set to off
Press the settings button i.e the button with the wrench icon on the machine. Now select "Print Report" and then "Image on Fax Send" and set it to "ON". Save the settings and try again. It should work.
Let me know if you need further help. Good Luck.
Thanks for using FixYa.
Mar 24, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I need a test fax to see if i can receive on my hp office jet pro 8500.
Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
When your fax is received by the HP Test Fax Service, It will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
I can not send or recieve faxes. Ran fax test
Cox Cable is pretty much the same as comcast's and vonage's services. HP fax machines have had HUGE compatibility issues with those types of services, and may be that they did something to their service that caused your fax to stop working.....
Other than that call HP and see if they have any troubleshooting or Diagnostics that you can run, but I ran in to these problems with HP faxes all the time while installing comcast phone service, never knew WHY it didn't work, just that HP doesn't work on that type of service.....at least certain models...Also maybe call COX and see if they did anything recently that could cause it to stop working....
Jun 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Can't fax
Can you send faxes to a local number? If you can the problem is likely to be that there is no long distance carrier set up for your new VOIP service. You could also try using a regular telephone connected to the same jack as the fax uses to try dialing a long distance number, this may give you a hint as to what's wrong. You should also contact Comcast tech support about this problem, the VOIP box may not be properly configured for long distance service.
Carl
Dec 04, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
2,554 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
