Question about Raypak HEADER GASKET
Replaceing head gasket on Daewoo Cielo 1995 need step by step
Head Gaskets Replacement
Here's a step by step on replacing your head gaskets.
May 28, 2013 | 1995 Chevrolet Camaro
Lost key for Daewoo Cielo 1996
Have a locksmith make you a new key or replace the lock barrel with a new set of keys.Try contacting the dealer and state the vin number of the car and they may be able to check records for the key code to cut new keys.
Feb 17, 2013 | Daewoo Nubira Cars & Trucks
Needing to know the head tension for deawoo cielo
daewoo lanos 1.6L dohc head torque is as follows , step 1 = 18 ft. lbs. , step 2 = 70 degrees , step 3 = 70 degrees , step 4 = 30 degrees . sequence is as pictured .
This should get you done -start with the middle head bolt and work your way out in a circle. Doing each one at step 1 - then the next bolt step 1 - then the next one step 1 - then go around again with step 2 - then around step 3 - 4 etc.
Gary @ Fix Ya
Dec 09, 2012 | Cars & Trucks
Speedometer just stopped working on Daewoo cielo 1995
check fuse box?
or the dash venicle needs replacing?
Oct 26, 2011 | 1999 Daewoo Lanos
I'am replacing the camshaft on a 1995 Daewoo Cielo, I have undone everything I can see but the camshaft will only slide about half a centimetre and won't move after that. Is there any trick in doing this?
you have to rotate the cam to push up all lifters and remove them then the cam should come out be vary careful not to scartch the bearing surface
Jan 16, 2011 | 1999 Daewoo Lanos
???? torque settings for daewoo cielo head single oh cam 1997 model
You can buy haynes manual for your car they are only fifteen dollars any they will have every torque setting you will possibly need and any other information you will need while you own the car it is a very usefull tool to keep with the car. Just maybe something to look into?
Nov 11, 2010 | 1999 Daewoo Leganza
Head gasket?
You remove air filter and other parts.
Then you remove head cover.
Then you unscrew and remove the head,
Clean a bit the block
Replace gasket.
Screw back the head
Follow head tourqe settings and screw orders on diagrams when mounting back the head.
The whole thing is not thst easy as it may seem, if you want to DIY you will need to buy the Haynes manual for your car. There you find a step by step procedure with pictures.
Here is a repair manual.
Also enquiry to Haynes.Haynes manuals are the best.
Here is how to replace head gasket on a Honda,
with lots of pics, procedure is the same, torque values and screwing order are different. It is not a job for absolute beginners
Do not forget to rate the solution
Thanks.
Aug 31, 2008 | 2000 Daewoo Leganza
Daewoo cielo speedo problem
Oh, i had this problem! you need to replace the clock i don't know the name but you need to replace the thing that shows you in which speed you are and the time and things.
Jun 10, 2008 | 1999 Daewoo Lanos
Raypak HEADER GASKET Logo
214 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
