Question about Acer CP-8531 Digital Camera
My camera does not charging , it also acts strange
When powered by wire it works ok but it wont charge the battery. It also shuts down unexpectedly without closing the lenses. I can not find any acer support web site for cameras. Anyone knows how to adress this problem would much appertiated.
  • 107 Answers
Checkout the battery and the charger.. if there is still problem then contact ur help desk
Posted on May 08, 2010
Canon 60d cannot turn on
when a camera won't power up, check a few things:
battery is charged. When the battery is in the charger, check if the charger acts like you are used to. The light should blink the same way and should go out, or start burning what the battery is charged.
Then check if the contacts on the battery and in the camera (battery holder) are clean and shiny. Eventually clean with a dry cloth or cotton swabs. Never use sharp tools. Then when the battery is in the camera again, listen and feel if the battery door locks correct.
The battery door or lid should engage a switch. That switch is there to stop all action, when the door is opened. Just to prevent memory damage, because the camera unexpectedly can lose power.
I hope it helps.
Jul 19, 2014 | Canon EOS 60D Digital Camera
Battery charging problem.
hi, its clear that the battery is gone .
replace the battery with a new one its gonna work fine.
when you plug the charging chord into the camera,the camera shuts down because the battery is gone.the battery has lost the ability to charge,so to protect your handycam from any hazard the camera shuts off.
take care bye & have a nice day.
Dec 13, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
The phone shuts down unexpectedly after a full charge than only shows 1% battery life
The battery either is not charging or for some reason discharging very rapidly
Mar 06, 2013 | Samsung HTC Sensation 4G Unlocked Cell...
My 1992 dodge ram power 250 cummins turbo diesel wont charge replaced alt and battery and still wont charge what can be my problem?
My 1992 Cummins W250 auto trans turned out to be the Computer/ECM mounted on front fender by battery tray. Mine only acted up in cold wheather. It started out with the ASD (auto shut down relay) clicking rapidly. In addition the water in fuel, wait to start and check engine light also blinked fast. In this state, the battery would not charge.
Sep 30, 2012 | 1992 Dodge Ram 250
Why does my HP dv6 shut down unexpectedly, even when it's charging?
Remove the battery and charger. set a timer for 3 minutes and hold down the power botton. this should take care of it.
May 30, 2012 | HP Computers & Internet
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
Wont charge while powered on or run on ac power
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
Kodak M753 wont charge
I hope this will work for you.
Clean all the gold termanels with a cotton swab and a little alcohol.
Make sure all surfaces are dry. Before you try to use it.
Apr 08, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Purchased a sanyo vpc-e870 yesterday ..let t he battery charge over night & 10 hours today...will not let me get past the date & time..shuts off 30seconds after i press ok?
If you read the instructions, you MUST use the external charger that comes with the camera to charge the battery, the camera wont charge the battery. The DC jack on the camera just powers the camera from the AC adapter, but doesnt charge battery
Apr 29, 2008 | Cameras
G2 PowerShot Power Problem
When you're charging the camera, make sure the power switch is set to OFF. We've run into the same thing- we could plug it in for days, but it won't charge at all if the power switch is on.
Hope that helps.
Jan 09, 2008 | Canon PowerShot G2 Digital Camera
Acer CP-8531 Digital Camera Logo
35 people viewed this question
Top Acer Cameras Experts
Joseph Hoffmann
Are you an Acer Camera Expert? Answer questions, earn points and help others
