Question about KitchenAid KT2651X Epicurean Stand Mixer
KitchenAid Epicurean 475watts Speed control problem
Hello, I have the mixer as stated above. My problem is that whenever you switch it on (stir-10) it goes into the highest speed. Switch control doesn't seem to have control of speed. I looked inside the cover, cleaned the dust build up and electrical contacts but this did not help.
I figured the resistor for the speed on the PCB logic board must be defective. I need a replacement board. Specs on the board says FSP.
Some numbers (PART nos?)
H01-03 H01-04
9706509 9706508
Rev-rel Rev-rel
I took a picture is you'd like me to send you a file.
Need to know where to get this board.
Thank you
Mario
Philippines
  • 1 more comment
  • mayong_md Apr 19, 2008
    To Fixya,
    I've solved my problem! I was able to buy a speed control with this part number:
    KA-9706648 KtchnAd 9706648/9706052 speed control, from Goodmans Online store.
    Waited for it 2weeks to get to the Philippines. It was a perfect bolt on fit into the mixer. And, voila! 10 speed mixing back.
    Thanks.
    Mario
  • peteloaf Dec 18, 2008
    when switched to stir it goes to max speed slowly then turns off
  • pamelaye Jan 06, 2009
    Ditto. Husband is electrician and said it was probably the switch. I went to mendingshed.com and found the part #9705505 (grey knob) $55 and #9705504 (black knob) $60. Don't know if they are refurbished or new parts. I've looked at alot of posts that had this problem. Hope this works.
5 Suggested Answers
  • 16 Answers
SOURCE: speed switch doesn't work, Hi speed only
Joedeven, I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.
Posted on Dec 30, 2008
  • 9 Answers
SOURCE: Kitchenaid Mixer K45SS
I just did this last week!
1 Unplug Mixer 2 Remove screw on TOP of mixer body, at back. 3 Remove rear cover and paper-gasket thing (its not the end of  the world if you end up tearing it a little). 4 the phase control (little circuit board w/wires) is at the top (you  should see it very easily) held on by one screw, remove it. 5 when the circuit board is unscrewed, disconnect all the wires  that are connected FROM THE CIRCUIT BOARD to the  black control plate (NOT all wires-there should be 4 left on  the control plate at this point).  you don't need to  remember where all the colors go as the control plate is  labeled->but looking at them and making sure you  understand the abbreviations would be beneficial  (BK=black, BL=Blue RW=Red&White W=white R=red etc.   6 install new phase control (screw), either buy new thermal  grease (used to keep the board cool->it transfers heat to  the mixer's housing) or try to salvage what you can from  the old one. 7 connect wires, paying attention to labels. 8 reinstall paper gasket, then cover, then screw to hold on back- cover.
Posted on Feb 09, 2008
defrankond
  • 65 Answers
SOURCE: My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed ....
ok to answer both of your questions. the mixer needs a new speed selector switch. it sounds to me like the contacts are burnt out or worn out one. the motor is fine its just the motor isnt getting the right voltage from the switch. its either on or off or medium speed or no speed. either way you both have to replace the switches. you can get the parts and do it yourself at kitchenaid.com or your local appliance store should be able to get them for you to.
Posted on May 05, 2008
SOURCE: kitchenaid mixer speed
I have the same problem. I contacted KitchenAid they blew me off with
"I am sorry to have learned you are experiencing problems with your KitchenAid product.
Your model and serial number indicate that your 2005 model Stand Mixer is outside of the warranty period, however you may find the part or repair for your appliance locally by contacting an authorized repair center in your area. To locate an authorized repair center please click on the following website link:
http://caservice.kitchenaid.com/
They obviously have a defective poor product now and will not stand behind it!!!
Posted on May 10, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 21, 2009
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Jan 28, 2013 | KitchenAid Food Mixers
Kitchenaid artisan mixer
The most likely answer is that you need a new speed control switch and there is a possibility that you may need a new worm gear. Can you give a more detailed explanation? What happened last time you used the machine?, what was happening when the problem occurred? What caused you to open the back cover? what else did you inspect or take apart or open up? Please send more info.
Jan 03, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Mixer doesn't work on all speeds
First the K45SS does not have a hall effect sensor. the pro series the epicurean seines and the pro series 5 use them, The K45ss system uses a phase control board a speed control plate and a governor for speed control. the governor rarely goes out the phase control board is a likely culprit but the system would work only in high gear if it was bad. I agree with the guest above in that it sounds like the retaining nuts on the adjusting screws of the speed control board have worked themselves loose and the adjustment screws themselves have vibrated out of proper position.
Sep 20, 2012 | KitchenAid K45SS Classic Stand Mixer
Where do i find speed control switch for kt2651xwwgh?
Hi, Craig.
When you said speed control switch, only one thing came to my mind. It's the one encircled in pink in the image below. Hope this helps.11_15_2011_1_30_31_pm.jpg
Nov 14, 2011 | KitchenAid KT2651X Epicurean Stand Mixer
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer KSM90EM turns off when going to the left on speeds 4 - 6. Makes a bit of noise at stir speed, but runs in time. Also noticed white dust powder in small amounts on the speed...
Get a Copy of the Repair Part List from Kitchenaid.com.
You need to adjust the mixer speeds:
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted. Make sure that the Control
Plate is not damaged in any way, contacts are not charred or burnt,etc...
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 30, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Only works speeds 6-8. Turns off when moving knob to lower speeds. Tightening two screws in the back of the mixer above the power cord changed the working range from 4-6. Any ideas?
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 26, 2011 | KitchenAid 32685 Mixer
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Stir/first level goes fullspeed and then turns off automatically
It shouldn't do that, and I really doubt there's anything you can do about it other than to have the defective part replaced. It sounds to me as though there's a problem with the control mechanism. If the machine is still under warranty, contact Kitchenaid to see about getting it repaired or replaced. If not, get the name of a local shop that repairs Kitchenaid mixers -- from your description of the problem, the mixer is nearly unless in its current state.
Jul 10, 2009 | KitchenAid Food Mixers
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
KitchenAid KT2651X Epicurean Stand Mixer Logo
626 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
